Solving a Hydrocarbon Molar Mass Problem
  • Thread starter Thread starter mohlam12
    Hydrocarbon Mass
The hydrocarbon problem involves determining the molar mass of a compound with 92.3% carbon and 7.7% hydrogen, given a smoke density ratio of 2.69 compared to air. The initial calculations suggest a ratio of carbon to hydrogen, leading to a formulation of equations to solve for the variables x and y. The density of the hydrocarbon's smoke is interpreted as a ratio of its molar mass to that of air, which is approximately 29 g/mol. By applying this density ratio, the molar mass of the hydrocarbon can be calculated as 2.69 times that of air. The discussion concludes with a confirmation of understanding the relationship between the densities and molar masses involved.
mohlam12
Hey everyone,
I have this problem to solve:
A hydrocarbon (CxHy) contains 92.3% of Carbon and 7.7% of Hydrogen.
1) What is its molar mass, if the density of its smoke to the air is d=2.69 ?
92.3/7.7 = 12
So 12x=y
This is the first equation. I have to find a second one to find what is x and what is y, in order to find the molar mass of CxHy.
Is the density of water to the air can be written as d=(molar mass of the compound)/(molar mass of the water) ?
Anyhelp/hints would be appreciated.
Mohammed
Which are the units of this density, g/dm^3 ?
Sounds like it is ratio of its density (in gaseous form) to the air density.
"Molar mass" of the air is about 0.78*28+0.21*32+0.01*40 (ie air has density as if it was gas of this molar mass). Hydrocarbon molar mass is 2.69 times higher.
Got It! Thanks Everyone :)
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
