Meaning of Differential Symbols δ & đ
The differential symbols δ and đ are used in thermodynamics to distinguish between exact and non-exact differentials. The lowercase delta (δ) indicates a change that is not path-independent, such as heat (dQ) and work (dW), while the d with a strikethrough (đ) emphasizes that these quantities are not total differentials. Total differentials, like internal energy (dU), are path-independent, meaning the change in energy does not depend on the process taken. The discussion also highlights the relationship between heat and work, noting that they are interdependent and can affect each other in thermodynamic processes. Understanding these distinctions is crucial for accurately analyzing thermodynamic systems.
ak416
What do the following differential symbols mean: δ, đ (the line is actually more slanted)
Ive seen these come up in my thermal physics class. For example δU or đW. Is the little delta equivalent to writing the uppercase "triangle" delta? Also i think the d with the line has something to do with dependence on direction. Am i right?
Mathematics news on Phys.org
It has to do with being a 'total differential' (such as dU) or not (such as q and w in dU = dq + dw) which is why a strikethrough is sometimes used for the d of dw and dq, to emphasize that those are not total (or exact) differentials. A total differential is path-independant, the others aren't.
In thermodynamics, that notation typically means that you haven't got an exact differential.
Well i know when writing an equation such as dU, we must write: dU = ∂U/∂Q *dQ + ∂U/∂W *dW . But in this case What's W and Q. If they call dW "Work done on system" and dQ "Heat added to system" Then i guess its meaningless to call W something right? And if dQ = T*dS I guess we can call Q = TS ? Sorry if this is getting off the "math" topic but if anyone can answer this physical question it will help also. But as for the math, is there any connection between what I said and what you call a non exact differential? Like what do you mean path independent? Heat and Work can only move in one dimension (they're scalars)...
or by path dependent you mean that dQ and dW depend on each other and you can't keep one constant without changing the other?
I'll give a physical 'story' to show the difference between path dependence and independence. Say you're climbing a mountain and you're going from place A (at 100m heigth) to place B (at 600m heigth). The overall altidude difference you'll have accomplished is path-independent. It doesn't matter which 'road' (=> path) you use to go from A to B, you'll always have risen 500m. The distance you've traveled is path-dependen however! You can take the shortest way from A to B or you could 'go arround the mountain' using a twisty road instead, but you'll have done a lot more kilometers :wink:
Now back to thermodynamics: the interal energy is path-independent (and thus an exact differential). It doesn't matter which 'path' a system follows to go from situation A to situation B, the net change in interal energy will be constant. The work done however, is path-dependent (and thus not an exact differential) since you can achieve the change in situation in many manners, not all requiring the same amount of work to do.
Thermodynamics has been a while for me, I hope I didn't say anything stupid here and that it's a bit clear to you now :smile:
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
