How can I prove the continuity of sin(x) using common properties?
JonF
I’m having trouble showing that Sin(x) is a continuous function. I’m try to show it’s continuous by showing: 0<|x - x_0| < d => |sin(x) - sin(x_0)|<\epsilon
Here is what I have done |sin(x)| - |sin(x_0)|&lt;|sin(x) - sin(x_0)|&lt;\epsilon and |sin(x)|<|x| so -|x| < -|sin(x)| => |sin(x)|- |x| &lt; |sin(x)| - |sin(x_0)|&lt; \epsilon but I can’t seem to go anywhere from there.
What are you supposed to know about sin(x) and cos(x) particularly for x near 0? I suggest you start with sin(x)=sin(x0+(x-x0)) and use the formula sin(u+v)=sin(u)cos(v)+sin(v)cos(u), and proceed from there.
i tried the addition angle identity, it only seemed to make things worse :(
What definition of sine and cosine are you using? If you are using the (fairly) standard definition as the y and x coordinates, respectively, on the unit circle at angle \theta, then you are going to have to use some geometric properties.
It would be helpful to know what definition you are using. Expanding mathman's out line a standard proof becomes obvious if these well known properties are first established
1)for all real numbers x and y
sin(x/2)-sin(y/2)=2*cos(x+y)*sin(x-y)
2)for all real numbers x
cos(x)<=1
3) for all real numbers x
|sin(x)|<=|x|
Thus the given problem
show that |sin(x)-sin(y)| can be made small by chosing |x-y| small
becomes
show that |sin(x)| can be made small by chosing |x| small
