Solving ODE Using Powersums: Fred's Solution
  • Thread starter Thread starter Mathman23
    Ode
Mathman23
Hi
Given a power-series
\sum_{n=0} ^{\infty} \frac{2^n}{2n+1} z^{2n+1}
if f(x), for z = x \in \mathbb{R} is the sum of the above power series. Then show that f is solution for the differential equation
\frac{dx}{dy} - 2xy = 1
My Solution
The generic form of this power series is f(x = z) = \sum_{n=0} ^{\infty} \frac{2^n}{2n+1} z^{2n+1}
Therefore \frac{dx}{dy} = \frac{d}{dx}(z) = \sum_{n=0} ^{\infty} 2^n \cdot z^{2n}
If I insert this above information into the ODE I get:
\sum_{n=0} ^{\infty} 2^n \cdot z^{2n} - 2z \sum_{n=0} ^{\infty} \frac{2^n}{2n+1} z^{2n+1} = 1
If this is correct do I try to put it all into one sum?
Sincerley
Fred
The above is wrong. Especially where you write \frac{d}{dx}(z). Look, don't confuse yourself with x and z. You have a function:
f(x) = \sum_{n=0}^{\infty}\frac{2^n}{2n+1}x^{2n+1}
To see if it is a solution to
you need to check that:
\frac{dx}{df} - dxf = 1
Note:
\frac{dx}{df} = \frac{1}{\frac{df}{dx}}
You want to verify:
\frac{1}{\sum_{n=0}^{\infty}2^nx^{2n}} - 2x\sum_{n=0}^{\infty}\frac{2^n}{2n+1}x^{2n+1} = 1
for all x.
Okay thank You,
Just to clarify then the next is write this down a have one sum sign and then factor out a commen factor ?
/Fred
If yes then I choose {\sum_{n=0} ^{\infty} 2^n x^{2n}} as the commen denominator.
Then I get \sum_{n=0} ^{\infty} \frac{1- 2x^2 \sum_{n=0} ^{\infty} (2^n * x^{2n}) \sum_{n=0} ^{\infty} \frac{2^n x^{2n}}{2n+1}}{{\sum_{n=0} ^{\infty} 2^n x^{2n}}} - 1 = 0
If this is correct, do I need to get rid of the sum in the denominator?
Sincerely
Fred
No, you get:
however I can't see why you'd want to look at it this way. Something's wrong with the question, since the series:
\sum _{n=0}^{\infty}\frac{2^n}{2n+1}x^{2n+1}
doesn't even converge for all x \in \mathbb{R}. Maybe you're only supposed to look at these series as formal power series, but then I don't see why they would say x \in \mathbb{R}. Actually, even looking at it that way the thing you're asked to prove appears false. I think you copied out the question incorrectly.
Hello AKG,
Looking at the question again:
Given a power series:
\sum_{n=0} ^{\infty} \frac{2^n}{1 \cdot 3 \cdot 5 \cdots (2n+1)} z^{2n+1} = z + 2/(1 \cdot 3) z^3 + 2^2/(1 \cdot 3 \cdot 5) z^5 + \cdots
converge for all z \in \mathbb{C}.
Let f(x) for z = x \in \mathbb{R} describe the sum of the above series.
Then show that f is a solution for
thats the exact problem. Any idears?
Sincerely
Fred.
p.s. Isn't
\sum_{n=0} ^{\infty} \frac{2^n}{1 \cdot 3 \cdot 5 \cdots (2n+1)} z^{2n+1} = \sum_{n=0} ^{\infty} \frac{2^n}{(2n+1)} z^{2n+1}
Mathman23 said:
p.s. isn't
No, it isn't! The only difference I can see between the two is than in one the denominator is 1*3*...*(2n+1) and in the other the denominator is 2n+1 and those are certainly NOT the same!
Your notation is still abominable! If z = x \in \mathbb{R},
then x is NOT a function of y and so \frac{dx}{dy} - 2xy = 1 makes no sense. Perhaps you meant
y(z)= \sum_{n=0} ^{\infty} \frac{2^n}{1 \cdot 3 \cdot 5 \cdots (2n+1)} z^{2n+1} = z + 2/(1 \cdot 3) z^3 + 2^2/(1 \cdot 3 \cdot 5) z^5 + \cdots
satisfies the equation
\frac{dy}{dz} - 2zy = 1
Yes,
\frac{dy}{dz}= \sum_{n=0} ^{\infty} \frac{2^n}{1 \cdot 3 \cdot 5 \cdots (2n-1)} z^{2n}
so the left side of the equation becomes
\sum_{n=0} ^{\infty} \frac{2^n}{1 \cdot 3 \cdot 5 \cdots (2n)} z^{2n}+\sum_{n=0} ^{\infty} \frac{2^n}{1 \cdot 3 \cdot 5 \cdots (2n+1)} z^{2(n+1)}
Now, In the first sum, let j= n so it becomes
\sum_{j=0} ^{\infty} \frac{2^j}{1 \cdot 3 \cdot 5 \cdots (2j)} z^{2j}
And, in the second sum, let j= n+1 so n= j-1. Of course, when n= 0, j= 1 so the second sum becomes
-2\sum_{j=1} ^{\infty} \frac{2^j}{1 \cdot 3 \cdot 5 \cdots (2j-1)} z^{2j}
except for j= 0, those are exactly the same but of different sign and so every term except the z0 term cancels. What is \frac{2^j}{1 \cdot 3 \cdot 5 \cdots (2j)} z^{2j} when j= 0?
Hello and T.Y for Your answer,
If You were going to express the dernominator for powerseries in a program like Maple, how would you express it?
(2n+1)! = 1*3*...*(2n+1)
What is \frac{2^j}{1 \cdot 3 \cdot 5 \cdots (2j)} z^{2j} when j= 0?[/QUOTE]
My calculator finds the resultat to equal 1.
I guess that proves that the sum is solution for the ODE ?
Sincerely
Fred
NO! Don't you know what "!" factorial is?
There is STILL something wrong with your question. Could you PLEASE take the time to copy it out correctly. Do you really mean dx/dy?
Just to explore the series itself a little more,
y = f(x) = \sum_{n=0} ^{\infty} \frac{2^n}{2n+1} x^{2n+1}
Differentiating term by term,
S(x) = f'(x) = \frac{dy}{dx} = \sum_{n=0} ^{\infty} (2^n) x^{2n} = 1 + 2x^2 + 4x^4 + 8x^6 + ...
Now observe that -2x^2S(x) = -2x^2 - 4x^4 - 8x^6 - ...
giving (1-2x^2)S(x) = 1
and S(x) = f'(x) = \frac{1}{1-2x^2}
From this we can get \frac{dx}{dy} = (1 - 2x^2)
We can also find an expression for f(x) by integrating S(x),
f(x) = \int f'(x)dx = \int \frac{1}{1-2x^2}dx = \frac{1}{2\sqrt{2}}\log{\frac{\sqrt{2} + 2x}{\sqrt{2} - 2x}}
Note that the constant of integration is zero because from the orig. series, f(0) = 0.
We can also get -2xy = -2xf(x) as -2xy = -\frac{x}{\sqrt{2}}\log{\frac{\sqrt{2} + 2x}{\sqrt{2} - 2x}}
Now we have explicit expressions for everything, but I still can't see how \frac{dx}{dy} - 2xy = 1:confused:
If he meant dx/dy, it definitely doesn't work. If he meant dy/dx, it does:
f(x) = \sum_{n=0} ^{\infty} \frac{2^n}{1 \cdot 3 \cdot 5 \cdots (2n+1)} z^{2n+1}
f'(x) = 1 + \sum _{n=1} ^{\infty}\frac{2^nx^{2n}}{1 \cdot 3 \cdot 5 \cdots (2n-1)}
-2xf(x) = -\sum_{n=0} ^{\infty} \frac{2^{n+1}x^{2(n+1)}}{1 \cdot 3 \cdot 5 \cdots (2n+1)} = - \sum_{n=1} ^{\infty} \frac{2^nx^{2n}}{1 \cdot 3 \cdot 5 \cdots (2n-1)}
This whole problem was really, really easy, made incredibly difficult by horrible communication. Next time, write the question exactly as it's given to you.
Why does (2n+1)! appear in the denominator of your f(x)? That wasn't in the orig. question.
See post #5 in this thread. The original poster thought (2n+1) = 1.3.5...(2n+1). By the way, is (2n+1)! some notation for 1.3.5...(2n+1)? Is ! only defined for odd numbers? What's it called?
It's the double factorial. It can be defined for evens as well the same way, except you end at 2.
You mean the question was wrong to begin with?
EDIT : Just looked at post 5. To the OP (Mathman) - PLEASE make the effort in future to write the question exactly as it appears, if you make a faulty assumption (like (2n+1)! = (2n+1) ) then all our efforts are for naught.
I'm very sorry,
It was suppose to say
Hello AKG,
\frac{dy}{dx} - 2xy = 1
Sincerely
Fred.
Mathman23 said:
I'm very sorry,
Hello AKG,
Sincerely
Fred.
AKG has already solved this problem in post 11.
By the way I realized that 1*3*5****(2n+1) = (2n+1)^n.
Sorry for me being confused. I need to read the problems more preciously.
/Fred
What? No, that's not true at all.
Then
Must equal
\sum_{n=0} ^{\infty} \frac{2^n}{(2n+1)!} z^{(2n+1)}
/Fred
