Photon coming from a far away star is redshifted?
  • Thread starter Thread starter Ratzinger
    Photon Star
Photons from distant stars are redshifted due to the expansion of the universe, which stretches their wavelengths. This redshift can be observed by comparing the unique spectral lines emitted by nearby and distant objects, revealing a consistent shift towards the red end of the spectrum. Some scientists question the constancy of fundamental physical constants, like the Planck constant, suggesting they may have varied over time, which could affect redshift measurements. However, the prevailing view is that the laws of physics have remained stable since the Big Bang, allowing for reliable extrapolation of redshift data. The discussion highlights the complexities of redshift interpretation and the implications for our understanding of cosmic evolution.
Ratzinger
How do we know that a photon coming from a far away star is redshifted?
Since we only can measure wavelength here on Earth how do we know that its wavelength was shorter when emited?
thanks
Space news on Phys.org
thanks
Exicted atoms emit specific, unique spectra. It is these fingerprint-like patterns which are shifted. Since these patterns are conserved, we can determine the redshift.
There's a picture at wikipedia;
http://en.wikipedia.org/wiki/Redshift
That might help. You can see the pattern of lines in a nearby object (the sun) and compar them to the lines in a distant star. The pattern of lines is nearly identical, and if you take the near object and move all its spectral lines just a little bit toward the red, they match up perfectly with the spectral lines of the more distant light source. The very likely conclusion; the two are emitting the same spectrum of light, and light from the more distant objected is shifting towards the red.
Basically, we don't.
Trouble is that these photons set off a very long time ago. Arp says that maybe some of these constants like the Plank constant are time dependent and had a different value a few million years ago.
After all, we have only been measuring them for 100 years so how can we extrapolate back and say that since they have been constant for the last 100 year or so (- within expermental error) they have been constant for all time?
E = hf,
if h changes the frequency changes and so wavelength was different when they set off. hence redshfted
E = hf,
Most scientists assume the laws of physics are the same at all times and places in this universe. Of course, this assumption is unprovable. But, when you apply that assumption to observational evidence, you get answers that make sense. On the other hand, if you attempt to get cute and 'tweak' things, like h, you get bizarre results that throw everything out of synch - sort of like the string landscape [sorry, I coudn't resist].
That is not true. Since a look into space is a look back in time and the universe looks the same everywhere, we can say with a high degree of certainty that the laws of physics are the same everywhere and have been for at least most of the way back to the Big Bang. If things like the Planck constant were even a little different a billion years ago, the universe of a billion years ago would look vastly different from what we see.
Space Tiger will be proud of me here.
In the BB, as one looks further and further out one looks further and further back in time. Heavier elements are formed by supernovae explosions and so one would not expect to find iron in distant early, unformed galaxies. And we, followers of the BB, say that that is what you find. That is, you do see aging (or should that be un ageing?) as you look at galaxies further and further away.
Without it the BB would be incorrect.
Cheers,
A truly converted Ratfink.
Iron enrichment is not really an issue in the early universe. Population III stars can easily explain that observation.
Actually it is an issue - the accretion disks of some high-z quasars show an iron abundance 3 x solar, e.g. APM 08279+5255at z = 3.91 whose estimated age is 2.1 Gyr when the universe was only 1.6 Gyrs old (according to LCDM model expansion).
The discovery of the quasar, the APM 08279+5255 at z = 3.91 whose age is 2-3 Gyr has once again led to ``age crisis''.
There are several more high-Fe high-z quasars known.
Although PopIII stars can explain other high-z metallicity, it is difficult to explain how so much iron formed so early as iron is the last element to be created in the nuclear fusion process.
This point is emphasised by Drs. Norbert Schartel, Fred Jansen and Prof. Guenther Hasinger in their ESA web-page article Is the universe older than expected?
Since iron is released by exploding stars, according to precise physical phenomena, and scientists think it builds up across the Universe gradually with time. The Solar System formed just 5 thousand million years ago, so it should contain more iron than the quasar, which formed over 13.5 thousand million years ago. The fact that the quasar contains three times more iron than the Sun is therefore a major puzzle
What might this be telling us?
One possible explanation is that something is wrong with the way astronomers measure the age of objects in the Universe. The almost-holy red shift-distance-age conversion would therefore be wrong. Fred Jansen, ESA's project scientist for XMM-Newton, explains that this would mean rewriting the textbooks. "If you study the evolution of the Universe, one of the basic rules is that we can tie redshift to age. One distinct possibility to explain these observations is that, at the redshift we are looking at, the Universe is older than we think."
You do not have to throw out the 'z' - 'observed age' relationship, that depends on the cosmological scale factor R(t), which occurs in the Robertson-Walker metric.
Perhaps R(t) simply needs adjusting? (again!)
Garth
Cheers,
I recognize that we see differences in age as we look further away. I wasn't saying we don't.
So are you taking this back?
Cheers,
Ratfink
Hubbleshift & Dopplershift
Talking about redshifted radiation in our universe it seems good to me to take into consideration the 2 sorts of shift mechanisms.
The first one is the Doppler-effect (speed difference dependent) en the second one is the Hubble-shift (distance difference dependent). Whenever the expansion stops, its related frequency shift (Hubble-shift) of radiation during its trip through the universe will be frozen while its related Doppler-effect disappears. Other Dopper-effects of relatively moving radiation-sources will continue.
I suppose I am right.
