Why do unexpected precipitates form in precipitation reactions?
Unexpected precipitates in precipitation reactions can arise from several factors, including contamination from improperly cleaned test tubes or mislabeling of substances. The presence of additional ions, such as those found in tap water, can also influence the outcome. Temperature sensitivity plays a crucial role, as certain reactions require specific conditions to proceed correctly, and the age or condition of the glassware can affect results. Additionally, coprecipitation and the solubility of the precipitate must be considered to ensure proper formation. Understanding these variables is essential for successful precipitation reactions.
danago
Hi. If i was to conduct a few precipitation reactions, is there any reason why an unexpected precipitate will form, or any reason an expected precipitate will not be formed? I've though about things such as added ions in tap water (chlorine etc). Any other things?
Perhaps the test tubes were not cleaned properly and some ions from the previous experiment were left behind. Maybe there was nothing wrong and it was the lab technicans fault for incorrectly labeling the bottles containing the substances.
lol :smile:
Some precipitation reactions are very sensative to temperature and some, like the silver mirror experiment, require rough surfaces or some point to start precipitating from (seed).
I have had such test fail or succeed just on the basis of the age of the test tube, with better results in older (scratched) glass tubes than in out-of-the-box tubes that are smooth.
Yes, that as well as other factors e.g. coprecipitation etc...precipitation isn't so simple as adding the components. Unless carefully devised the precipitated product may be more or less crude. Since this is probably for general chemistry you won't have to worry about the analytical aspects too much, but in actuality the process is drawn out. In your case, I would consider the solubility of the particular precipitate, so as to account for the volume of solvent needed, you want to be well over the point of saturation to see the solids. Also, consider the temperature, you may need to heat the solution to digest sample and then cool it down to a certain temperature; that is sometimes it's preferable to employ an ice bath.
Thanks for the help everyone :)
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
