Optimizing Restaurant Seats for Maximum Profit
  • Thread starter Thread starter coolant
    Maximum
coolant
In planning a resturant, it is estimated that a profit of $5 per seat will be made if the number of seats is between 60 and 80, inclusive. On the other hand, the profit on each seat will decrease by 5 cents for each seat above 80?
a) Find the number of seats that will produce the max profit
b) what is the max profit?
Make a hand plot first. What is the answer? Then use calculus to find the maximum. What is the answer? They should match, eh? Welcome to PF!
You don't really need calculus since the marginal profit is almost given to you. Just stop adding seats when the marginal profit is less than 0.
You don't say what the "profit" is, if any, if the number of seats is less than 60 so I will assume it is not defined for x< 60.
Okay, the profit function, for x seats, is
P(x)= 5x if 60<= x<= 80
= (5- 0.05(x-80))x if x> 80
As Orthodontist said, you don't really need calculus since the marginal profit is "almost given to you" but you can:
P'(x)= 5 if 60<= x<= 80
= -0.05x+ (5- 0.05(x-80))
For what value of x is that equal to 0?
Actually, I think the additional profit on placing the x'th seat for x > 80 is
-.05(x-1)+(5-.05(x-80))
Since with each seat, you
1. Lose 5 cents on each seat already placed, which is x-1 seats
2. Gain (5-.05(x-80)) dollars on the current seat
A strict derivative would only be approximate since this is discrete.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
