Forces with direction and magnitude
dopey9
A particle of mass m kilograms is acted on by two forces F[1] and F[2] with magnitudes 3*sqr-root 5 Newtons and sqr-root 5 Newtons and directions parallel to the vectors i+2j and i-2j respectively.
The particle is initially at a position given by the vector 2i+j
i was told to calculate the cartesian components of F[1] and F[2] and hence calculate the total force F[1] + F[2], acting on the particle in component form
MY SOLUTION
i got F[1] as:
x=3*(root5)*cos(theta)
y= 3*(root5)*sin(theta)
i got F[2] as:
x=(root5)*cos(theta)
y= (root5)*sin(theta)
and then F[1] + F[2] as:
F[x] = 4*(root5)*cos(theta)
F[y] = 4*(root5)*sin(theta)
i was just wondering if i have done it right ?
from there i need to show the couple of the total force about the point with position vector i is zero.....does any understand this part or know how to do it ?
But you don't know theta, do you? So those formulas a pretty much useless. Yes, you could calculate theta from the vectors they give you but that would be like going east around the world to get to a destination 1 mile west of you!
The vector i+ 2j has length \sqrt{1^2+ 2^2}= \sqrt{5}
A vector in that direction, with length 3\sqrt{5} is just 3 times that: 3i+ 6j. That's your first force vector.
Similarly, the vector i- 2j also has length \sqrt{5} so that is the second force vector. The total force, then, is F1+ F2= (3i+ 6j)+ (i- 2j)= ?
For the second question I recommend that you first look up the definition of "couple of a force about a point".
need my answer checked!
i've looked at the definition n various examples..but they are not similar to the one I am doing so i can't really figure out how to show the couple of the total force about the point with position vector i is zero...
im assuming that it is a single force...but a couple cannot be put in equilibrium by a single force!
can some help me with this question...by showing me how to do it or telling me the steps to sove it ...thankz
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
