From SR to GR in an easy math (and physical) way
  • Thread starter Thread starter lokofer
    Gr Physical Sr
lokofer
From SR to GR in an "easy" math (and physical) way
Hello..i know that for example to go from Newtonian to SR you take:
\frac{du}{ds}=0 \rightarrow \nabla _{u} u=0
My question is ¿is there an "easy" form to go from SR to GR in the form:
\nabla _{u} u=0 \rightarrow \nabla R_{ab} =0
Or to get Einstein equation appart from using the Lagrangian formalism... using "Differential Geomertry" or similar...:confused: :confused:
Your first claim doesn't make much sense to me. Can you clarify?
Are you trying to describe the evolution of the universe as a geodesic in some abstract space?
OK, so this has bugged me for a while about the equivalence principle and the black hole information paradox. If black holes "evaporate" via Hawking radiation, then they cannot exist forever. So, from my external perspective, watching the person fall in, they slow down, freeze, and redshift to "nothing," but never cross the event horizon. Does the equivalence principle say my perspective is valid? If it does, is it possible that that person really never crossed the event horizon? The...
In this video I can see a person walking around lines of curvature on a sphere with an arrow strapped to his waist. His task is to keep the arrow pointed in the same direction How does he do this ? Does he use a reference point like the stars? (that only move very slowly) If that is how he keeps the arrow pointing in the same direction, is that equivalent to saying that he orients the arrow wrt the 3d space that the sphere is embedded in? So ,although one refers to intrinsic curvature...
ASSUMPTIONS 1. Two identical clocks A and B in the same inertial frame are stationary relative to each other a fixed distance L apart. Time passes at the same rate for both. 2. Both clocks are able to send/receive light signals and to write/read the send/receive times into signals. 3. The speed of light is anisotropic. METHOD 1. At time t[A1] and time t[B1], clock A sends a light signal to clock B. The clock B time is unknown to A. 2. Clock B receives the signal from A at time t[B2] and...
