Detecting Spectral Lines in Explosions
Detecting spectral lines in explosions, particularly from a powerful blackbody, poses challenges due to the intense heat and luminosity. A sensitivity model for a short wave IR spectrometer can aid in this detection process. Using an optical pyrometer can help determine the temperature of the explosion, which is essential for identifying characteristic emission lines from specific elements. This approach allows for the analysis of spectral lines despite the overwhelming background radiation. Understanding these methods is crucial for accurate spectral analysis in high-energy environments.
rp895
Hi All,
I am working on a sensitivity model for a short wave IR spectrometer. And I have come up to a few questions that I had never thought of before and that seem really interesting (and I still don't know the answers, so it'd be great if anyone had any insight!)
Well, I need to look at an explosion (say powerful blackbody) and take an IR spectrum to detect few things. Now, the explosion itself is hot and luminous, so how do i detect the spectral lines I want? In short, how do you detect any spectral lines in such an environment?
Thanks for any help...
rp895
Well, one can look at look at a blackbody radiator to look at the temperature (basis of optical pyrometer) and then look at particular (characteristic) emission lines from particular elements, based on the temperature determined from the optical pyrometer.
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
