Bullet hitting block attached to spring
A bullet weighing 0.0125 kg strikes a 0.300-kg block attached to a spring with a spring constant of 2.25 x 10^3 N/m, causing it to vibrate with an amplitude of 12.4 cm. The energy stored in the spring is calculated to be 17.30 J. Using conservation of momentum, the initial speed of the bullet was found to be 10.52 m/s after correcting the calculations. The initial velocity was initially miscalculated, leading to confusion about the final results. The corrected values confirm the calculations are now accurate.
needhelp83
A 0.0125 kg bullet strikes a 0.300-kg block attached to a fixed horizontal spring whose spring constant is 2.25 x 103 N/m and sets it into vibration with an amplitude of 12.4 cm. What was the speed of the bullet if the two objects move together after impact?
E=(1/2)kA^2=(1/2)(2250 N/m)(0.124 m)2=17.30 J
m=0.0125 kg + 0.3 kg=0.3125 kg
K=(1/2)mv^2
17.30 J=(1/2)(0.3125 kg)v^2
v2=0.009
v=0.095 m/s
Conservation of momentum:
(.0125 kg)v=(0.3125 kg)(0.095 m/s)
v=2.375 m/s
Have I done this properly? The velocity doesn't seem right to me. Have I missed anything?
needhelp83 said:
K=(1/2)mv^2
v2=0.009
v=0.095 m/s
Redo this calculation.
K=(1/2)mv2
17.30 J=(1/2)(0.3125 kg)v2
v2=110.72
v=10.52 m/s
(.0125 kg)v=(0.3125 kg)(10.52 m/s)
v=152.91 m/s
Yes, this looks better. Thanks for the help!
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
