Is Strain Dimensionless According to Dimensional Analysis?
  • Thread starter Thread starter wakejosh
    Strain
wakejosh
The quantity "strain" expressed in terms of the fundamental quantities (mass, length, time) is equivelent to?
isn't this dimensionless?
Yes it is unitless! Strain doesn't have units -- it's the change in length per unit length.
Absolutely. Use dimensional analysis if you have problems.
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
