Direct TV Signal Issues: Can't Receive in Boat
  • Thread starter Thread starter Tom B.
    Signal
A user is experiencing issues receiving a Direct TV signal on their boat after relocating their satellite dish, despite it working previously in the same spot. They have tested the setup in different locations successfully, indicating the problem may be location-specific. Suggestions include checking the new LNB and receiver box for functionality, as well as considering potential interference from newly installed microwave towers nearby. However, it's noted that both microwave and satellite dishes are highly directional, making interference unlikely. The discussion emphasizes the importance of ensuring all components are correctly installed and functioning.
Tom B.
I moved a sattelite TV dish from my house to my boat. Set everything up as it should be but cannot receive a signal. Everyone around me is receiveing just fine. Took everything down and hooked it up at a different location and get a signal with no problem. Cannot figure out why the is no signal in the one spot where my boat is. Was in this very same spot in the Spring and every thing worked great.
There are a lot of variables that you have left out, some more details on the location are required to even begin to make an educated guess.
I would bet the first time you had something hooked up wrong. The old EE saying is "95% of problems are cable problems."
Installed a new LNB, a different receiver box with all new cables from the dish to the box to the TV. I have been told me since my post that there were new Microave towers installed over the summer. Could their signsl knock out a sattelite transmission?
If you installed an new LNB, are you certain that it works? Getting a satellite signal is not that tough. Most LNB's I have seen have a blinking LED that, when you are in the set up mode, blinks to give you an idea of signal strength. Also, since you have a new box, have you used that box anywhere else? Do you get any messages on the screen not related to the antenna? I would think you've got a kink somewhere else in your system.
Doubtful. Both the uwave dishes and your satellite dish are highly directional.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
