Mean and standard deviation probability help
The discussion revolves around calculating the probability that the sample proportion of credit sales exceeds 0.34 in a department store's sales data. The user calculated the mean (mu) and standard deviation (sigma) for the sample size of 75 with a credit sales proportion of 25%. The computed z-score was 1.8, leading to a probability of 0.0359 for the sample proportion being greater than 0.34. Clarification was provided regarding the use of the z-table, emphasizing that it gives P(z<Z), thus requiring a subtraction from 1 to find P(z>Z). The user also noted an alternative formula for standard deviation of a sample proportion, prompting a discussion on which formula to apply.
413
A department store has determined that 25% of all their sales are credit sales. A random sample of 75 sales is selected and the proportion of credit sales in the sample is computed.
a) What is the probability that the sample proportion will be greater than 0.34?
my answer is:
n=75 p=0.25
mu=np=18.75
sigma=sqrt(n*p*(1-p)) = 3/75
0.34 * 75=25.5
z=x-mu/sigma = 25.5-18.75/3.75 =1.8
P(z>1.8)=0.0359
the answer i got is 0.0359 but i am not confident, please tell me if i am correct or not. Thanks.
oh, i just found another equation for mean and standard deviation of a sample proportion is mu=p and sigma=sqrt(p(1-p)/n)
which one should i use for this question?
One big thing:
The z-table in your book gives you P(z<Z) for a standardized normal random variable Z, not P(z>Z). So, P(z>1.8) = 1 - P(z<1.8) = 1 - phi(1.8). You may have already done that in your calculations but you did not specify that if you did.
The formula I have for sigma is: sqrt(npq) where q=(1-p).
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
