Are These Collections of Subsets Partitions of the Set of Integers?
  • Thread starter Thread starter brad sue
    partitions Urgent
brad sue
Hi I need help with this problem I have some trouble with partitions:
The context is Discrete math /relation
Which of these collections of subsets are partitions of the set of integers?
1- The set of even integer and the set of odd integers.
2- the set of positive integer and the set of negative integers.
3- the set of integers divisible by 3, the set of integers leaving a remainder of 1 when divided by 3, and the set of integers divisible by 3, the set of integers leaving a remainder of 2 when divided by 3.
4- The set of integers less than -100, the set of integers with absolute value not exceeding 100, and the set of integers greater than 100.
5- the set of integers not divisible by 3, the set of even integers and the set of integer that leave a remainder of 3 when divided by 6.
Are my answers correct?
I found yes for all cases . but I am suspicious.
Thank you for your help
B
The definition of "partition" of a set is a collection of subsets such that every member of the orginal set (here the set of all integers) is in one and only one of the subsets.
Is there any integer that is in neither of these sets- is there any integer that is neither even nor odd? Is there any integer that is in both- is there any integer that is both even and odd? If your answer is "yes" to either, then this is not a partition. If it is "no" to both, then it is a partition.
Again, is there any integer that is neither positive nor negative? Is there any integer that is both positive and negative?
Is there any integer for which two of these is true- can an integer have two different remainders when divided by 3? Is there any integer for which none of these is true? What are the possible remainders when you divide a number by 3?
Do you see what questions you should ask yourself for this? Is there any integer for which two of these is true? Is there any integer for which none of these is true?
Are my answers correct? ?What were your answers?
B
Oh, I see. Your answered "yes" for every question. No, that is not true. Go back and answer the questions I asked for each one.
Thank you HallsofIvy
I understand what I need to ask myself .
I have an exam in 15 min. I going to go now and work on it.
Thank you..
