How Do Eigenvectors of a Matrix Relate to Its Inverse?
azone
Suppose that B is the inverse of A. Show that if |psi> is an eigenvector of A with eigenvalue a not equal to 0, then |psi> is an eigenvector of B with eigenvalue 1/a.
So I know that A|psi> = a|psi>, and I'm trying to prove that A^(-1)|psi> = 1/a|psi>. I tried simplifying A as a 2x2 matrix and then doing the inverse of that. And then I assumed that the inverse of A has an eigenvalue b. So then I did the determinant of A^(-1)-b = 0 in the hopes to find b and see that it's equal to 1/a. But that became really messy.
Any suggestions on how to solve this problem? Thank you so much!
Start with A|psi> = a|psi> and solve for (isolate) |psi> in terms of inv(A). You should be able to take it from there.
well it is not too difficult:
you supposed A invertible and B=A^(-1).
since AB=BA=1---->[A,B]=0.
(1)|psi>=BA|psi>=Ba|psi>=AB|psi>=ab|psi>.
but ab=1 so the eigenvalue b must be b=1/a
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
