Find BPSK Modulator Chip for Project | BPSK Code
  • Thread starter Thread starter bearbear
A user is seeking a BPSK modulator circuit or IC chip for a project. Responses suggest utilizing the LM1496 Gilbert cell mixer chip and refer to MiniCircuits for additional resources. The importance of conducting independent research and learning about modulation is emphasized, with a recommendation to explore application notes on the National Instruments website. The discussion highlights the need for self-directed learning in project work. Overall, the focus is on finding resources and understanding BPSK modulation.
bearbear
i'm doing BPSK modulator for my project. can anyone please tell me where can i find a PSK modulator circuit? or a BPSK mdulator IC chip?wat is the code for the chip.:confused:
Welcome to the PF. What is your background? What class is this a project for? What learning materials are you using to understand modulation in general, and PSK in particular? Here is a basic reference about PSK:
http://en.wikipedia.org/wiki/BPSK
One fundamental circuit element that can be used for modulation is the Gilbert cell. Check out the App Notes on Mixers at this MiniCircuits.com page:
http://www.minicircuits.com/pages/app_notes.html
The old LM1496 is the basic Gilbert cell mixer chip, but you will need some circuit skills to use it. The simplest thing might just be to buy a mixer module from MiniCircuits...
help
:redface: thanks for your reply. but i can't find the circuit. can u please send me the complete circuit instead?
Nope. You need to do the legwork -- that's what a project is for. To help you learn about the subject, and to learn how to find information and use it. I'll give you a little push in the right direction, though... Go to www.national.com (the National Instruments website) and do a search on LM1496. That will give you several application notes, etc., on how the part is used for modulation. In case you have trouble getting there and doing the search, here's the hit list:
http://search.national.com/iphrase/query?query=LM1496
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
