Stargazing Build Concave Mirrors Up to 1.5M Dia: Design a Grinding/Polishing Machine
The discussion focuses on designing a grinding and polishing machine for manufacturing concave mirrors up to 1.5 meters in diameter. Participants share resources, including a link to a construction guide, and emphasize the importance of uniform pressure and motion in the grinding process. Suggestions include using pre-sphericized glass blanks for cost efficiency and the challenges of creating a clock drive for telescope mounts. One user proposes using an old car front wheel housing for stability in building an equatorial mount. Overall, the conversation highlights practical tips and considerations for both mirror fabrication and telescope mounting.
les trickett
We Are Trying To Design A Grinding/polishing Machine To Manufacture Concave Mirrors Upto 1.5 M Dia
Does Anybody Have Any Plans For Construction
Astronomy news on Phys.org
Try here:
http://www.oblivion.net/~astro/mirror/mom/construction.html
If you "Google" Grinding/polishing Machine you will find a lot of good links.
I have a Odyssey 1 Dobsonian and have been thinking of building an equatorial mount for it.
I am thinking of using an old front wheel housing from a junked car for base of the mount has anyone tried this or know someone who has?
I figured that the wheel housing would be over-kill but more is better than less when it comes to stability, as for the mount to the telescope itself I have some 1/2 inch steel plate that I can cut up and make a fork mount out of it. I know it will be heavy but it is going to be in a building and will not be moved.
Any suggestions for a clock drive and setting circles set up would be appreciated as well as any other construction tips.
Thanks
The principle for grinding a spherical surface is quite simple. Uniform pressure, linear motion of one of the surfaces, and rotation of the other surface. A small amount of randomness in the stroke, rotation speed or both is even better. Pre-sphericized glass blanks are commercially available pretty cheap. It's worth a look, you might be surprised how large and inexpensive these can be. It's not hugely expensive to make your own rig, but not cost effective unless you can sell a couple rough ground mirrors. Making clock drives is surprisingly difficult. You need gears with weird teeth numbers to make it work on house current [60 Hz], or some fairly pricy frequency converters. Albeit frequency converters might be a lot cheaper now than the last time I priced them.
This thread is dedicated to the beauty and awesomeness of our Universe. If you feel like it, please share video clips and photos (or nice animations) of space and objects in space in this thread. Your posts, clips and photos may by all means include scientific information; that does not make it less beautiful to me (n.b. the posts must of course comply with the PF guidelines, i.e. regarding science, only mainstream science is allowed, fringe/pseudoscience is not allowed). n.b. I start this...
Asteroid, Data - 1.2% risk of an impact on December 22, 2032. The estimated diameter is 55 m and an impact would likely release an energy of 8 megatons of TNT equivalent, although these numbers have a large uncertainty - it could also be 1 or 100 megatons. Currently the object has level 3 on the Torino scale, the second-highest ever (after Apophis) and only the third object to exceed level 1. Most likely it will miss, and if it hits then most likely it'll hit an ocean and be harmless, but...
