In science proving something by making it linear is a common?
  • Thread starter Thread starter lonerider
    Linear Science
In scientific analysis, linearization is a common method to simplify complex relationships, often using logarithmic transformations. The equation y=a*log(x)+b can represent a linear relationship when the variable is transformed, such as letting X=log(x), which results in a linear form y=aX+b. Plotting transformed variables, like (log(x), log(y)), can also reveal linear patterns in data that initially appear non-linear. Linear approximations, derived from Taylor expansions, help make complex functions more manageable for analysis. Overall, linearization is a valuable tool in scientific and engineering contexts for simplifying data interpretation.
lonerider
In science proving something by making it linear is a cmmon approach.
For instance you can write some laws on this form.
y=a*log(x)+b
But there lies my problem, because I cannot see how this should represent a linear line. So please does this represent a line? ANd if yes how come?
Mathematics news on Phys.org
That does not represent a linear function of x.
Perhaps a is of the form 1/(n log x)...>.<"
If you let X= log(x), then y= aX+ b is certainly linear. I imagine that is what you are thinking of. If you have data that does not appear to fall on a straight line when you plot (x,y), plotting (X, y) with X= log(x) may help. Sometimes plotting (log(x), log(y)) will help.
Stationery stores used to sell "semi-log graph paper" and "log-log graph paper" that already had one or both axes marked in term of the logarithm so that the conversion was automatic.
Are you thinking of a linear approximation? Scientists and engineers use frequently use a linear approximation to make a problem more amenable to analysis.
In general, one makes a linear approximation to some function about some central point as the first-order Taylor expansion of the function at that point. For a one-dimensional function y(x), the linear approximation for x\approx x_0 is
y(x) \approx y(x_0) + (x-x_0)\left.\frac{dy}{dx}\right|_{x=x_0}
For your simple example, y=a\log x + b, the linear approximation for x\approx x_0 is
y(x) \approx a \log x_0 + b + a\frac {x-x_0}{x_0} = \frac a {x_0} x + a(\log x_0-1) + b
Linearizing around x_0=1 yields a very simple result:
y(x) \approx a (x-1) + b
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
