adamabel said:
Thanks! At least now the left side makes sense.
I don't know what a tensor is, but I do have an unread book on them. Maybe I should read it.
To me, this sounds like you can't be bothered to read the book, and expect me to explain it to you! However, this may not be the case, and if no-one in your class is familiar with tensors then there is no need to use them
A derivation of either the Euler or the Navier-Stokes equations would be fine (preferrably N-S). I do want to take into account friction, if this is all possible without tensors.
You can derive the NS equations without tensors since, in this case, the tensor can be written as a matrix.
I need to do a presentation in a math class-none of the other students have had too much physics (except maybe in high school), so I don't want to go into that in too much detail. Just a general derivation.
Well, in my opinion there is no such thing as a "general derivation". Especially if this is a Maths class, then a derivation is where equations are derived from first principles. I think you are after a brief(ish) explanation of why the equations come about.
I mean, I can introduce terms like viscosity and such, but it probably wouldn't be a good idea to go into tensors, even if I figured out what they were by the time I present. If nothing else, (if something like this works), I could just say: "the left side is the acceleration, and on the right side, f is external forces, \nabla p is the force due to pressure, and \nu\Delta u is a force due to a kind of friction. The second equation just says the fluid is incompressible."
What you've put in quotes here is not a derivation, or explanation, it is just a statement of the equation, and I don't think that this will do.
I would start with Newton's second law, in the form: time rate of change of momentum = sum of external forces.
From here it again depends how much maths you know. For example, have you come across triple integrals, divergence theorem?
Have you found any derivations on the internet? If you find one, and link to it, and say where your having difficulties, this will be a lot easier than me writing it out here!
