Need to design a sensing circuit
  • Thread starter Thread starter richt
    Circuit Design
The discussion focuses on designing a sensing circuit for small forces using QTC, a material that changes conductivity under pressure. Suggestions include using two series circuits with pressure switches and Schmitt triggers to activate different LEDs based on force thresholds. An alternative approach involves a window detector using op-amps to create two trigger levels defined by a resistor network. Participants emphasize the importance of experimentation and tweaking to achieve the desired sensitivity. Overall, the conversation provides practical circuit design ideas for a novice in electronics.
richt
Hi iam looking for help with a college project i am doing, it is for sensing forces but the forces are only small. I am using a material called QTC( which changes from an insulator to a conductor when a force is applied to it). I am not doing electronics at college, so i only have a limited knowledge of electronics and circuits. How would i design a circuit that would switch on an LED at a certain predetermined force, then if the force is too high it would then switch on alternate LED. if this sounds at all possible could somebody suggest a circuit to use, as i have said i am a novice when it comes to electronics. I have come across schmitt triggers but i do not know how they work. thank you in advance.
rich
well...
you could have two series circuits coming from a source like a battery...with one of those pressure switches under some padding...going into the schmitt trigger turning on LED A
have the other pressure switch under some MORE padding under the first one, hooked up the same way. Might use a transistor to get the right Vcc for the Schmitt triggers.
Then just do some physics calculations, experimentation, and tweaking until you have the right padding to close the pressure switches with the correct force
That's how I'd do it but I'm a bootleg college student
You can either use the solution suggested by Number2Pencil or you can get away with ONE opamp that does the job for you: it's called a window detector, it is like 2 Schmitt-triggers in one ;)
Basically, window detector is a device which will trigger on two occasions which are predefined by a resistor network that surrounds the opamp. So basically you'll have two trigger levels with some margin (window) which you define by resistor-setting.
I would probably take the output from your sensor to two op amp comparitors. This way you wouldn't be loading you sensor.
http://hyperphysics.phy-astr.gsu.edu/hbase/electronic/compar.html#c1"
The comparitors will each have a threshold that you can set by your choice of resistances. (you could use a variable resistor; R1 in the linked circuit)
Regards
You could use a force depandant resistor or a load cell depending on what you are doing.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
