How to Make a Self-Starting Motor with Basic Materials
  • Thread starter Thread starter LAdidadida
    Motor
To create a self-starting motor from basic materials, positioning the coil at the start of the power cycle is crucial for initial attraction to the magnets. Increasing the mass of the coil may help generate enough momentum to continue the cycle. The original design requires an initial push, which complicates achieving self-starting functionality. Implementing switching commutators can provide alternating attraction during each half of the cycle, enhancing self-starting potential. Overall, modifications to the coil's mass and the use of commutators are key strategies for achieving a reliable self-starting motor.
LAdidadida
I'm building a simple motor out of basic materials and at the moment its very similar to this one:
http://www.exploratorium.edu/snacks/stripped_down_motor.html
However it won't start unless I give it an initial push. One of the criteria I need to fulfill is that it needs to self-start.
Suggestions on how I might make the motor self-start, reliably as well?
All that I can think of for that particular type of motor would be to make sure that the coil is positioned at the very beginning of the 'power on' cycle so it will be attracted to the magnets right away. It still might not have enough momentum to carry through to the next cycle, though. Maybe increasing the mass of the coil would help...
Do keep in mind, though, that the write-up for the design calls for a push to get it going. It isn't intended to be self-starting.
Aside from that stuff, you might have to use switching commutators instead so you have alternating attraction during each half of the cycle.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
