Does Isothermal Heat Flow Out Contradict the Second Law of Thermodynamics?
  • Thread starter Thread starter neelakash
    Thermodynamics
neelakash
When there is a heat flow out of the system during a reversible isothermal processthe entropy of the system decreases.Why does this not violate the 2nd law of thermodynamics?
I hope this is correct.Please check and confirm.
Because the question uses the word "system" quite loosely. They are using "system" to mean the gas or other working substance from which the heat flows. But in terms of the second law, the word "system" refers to everything that loses or gains heat during the process.
So while the gas releases heat and the entropy of the gas decreases, the heat is absorbed by the environment (which must be included in the "system") and the entropy of the environment increases. Overall the total change in entropy is positive, as the increase for the environment is greater than the decrease for the gas.
when there is a decrease in this enrophy, the entropy of the surroundings increases, u are quite right. system in the law refers to everything
OK thank you.
In fact, if it's reversable, then the entropy increase of the surroundings exactly matches the entropy decrease of the system.
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
