Change the contents of a file into a string
The discussion centers on a Java code snippet designed to read and print the contents of a file containing flight information. The code successfully outputs details such as flight number, departure and arrival locations, and passenger information. The user seeks guidance on how to extract specific pieces of data, like the flight number and airport names, from the printed output. They suggest using string manipulation techniques, particularly searching for the ": " delimiter to isolate the desired information. The inquiry emphasizes the need for a straightforward method to convert the printed lines into usable strings for creating a Flight object.
JaysFan31
Hi. I'm in an elementary Java course and I wrote the following code to print the contents of a file I created earlier:
Code:
public static void load(String fileName) throws IOException
    try
      Scanner fileScan = new Scanner(new File(fileName));
      while (fileScan.hasNext())
        System.out.println(fileScan.nextLine());
    catch (FileNotFoundException exception)
        System.out.println("The file was not found.");
It prints (correctly) the following lines of the file:
Flight Number: 1234
From: Lester B. Pearson International Airport (YYZ): Toronto, Ontario
To: Not Set
7 passenger(s):
This represents a particular flight in a class I wrote before. I need to use this information to create a Flight object. I just need to know if there is an easy way to transform (using elementary Java code) all this information into a String so that I can get particular aspects of it. Basically, I need to get the flight number "1234" as a String. I need to get the original airport etc as Strings. Can I do this?
Technology news on Phys.org
Is there some way in java to search for a certain element? If so, you could search for the ": " that you have in front of each data item you (I think) are looking for. Anyway, just a random idea. Have a nice day.
fileScan.nextLine() is already a String.
Thread 'Is this public key encryption?'
I've tried to intuit public key encryption but never quite managed. But this seems to wrap it up in a bow. This seems to be a very elegant way of transmitting a message publicly that only the sender and receiver can decipher. Is this how PKE works? No, it cant be. In the above case, the requester knows the target's "secret" key - because they have his ID, and therefore knows his birthdate.
15K
11K
