Calculating Work Done by a Force on a Moving Object
The discussion centers on calculating the work done by a force on a block moving from -3.00 cm to 5.00 cm, using the formula W = F*S*cos(theta). Initially, the user calculated work as W = -260J, but realized a mistake in defining displacement. After correcting the displacement to 8 cm, the user recalculated the work as W = 680J. Participants emphasized the importance of consistent units and proper calculations in physics problems. The user expressed frustration over their initial errors but planned to revisit the problem later.
Abarak
Find the work W done on the block by the force of magnitude F = 85.0N as the block moves from xi = -3.00cm to xf = 5.00cm.
W = F*S*cos(theta)
W = (85.0N)(-3cm-5cm)*1
W = -260J
Am I missing something?
The definition of displacement.
And a consistent set of units
Let me try this again...
W = (85.0N)(3cm+5cm)*1
W = 680J
(3cm + 5cm) because the block is moving from -3cm to 0 and from 0 to 5cm. This gives us a grand total of 8cm the block was moved. Sorry for the rather rudimentary question.
W = -260J
a calculator??
and check the units
Newton * meter = joule
God, that was terrible. I'm going to stop right now and start again tomorrow. Sorry for the waste of time.
