Vacuum required to generate specific amount of force
The discussion focuses on calculating the pressure required for a circular vacuum cup with a diameter of 4.5 inches to generate 120 pounds of force. The user correctly applies the formula P = F/A, resulting in a pressure of 7.55 psi. This pressure converts to approximately 15.36 inches of mercury (Hg) using the conversion factor of 1 psi = 2.036 Hg. The user acknowledges the need to account for atmospheric pressure to determine the absolute pressure inside the cup.
  • Understanding of basic physics concepts, specifically pressure calculations.
  • Familiarity with the formula P = F/A (Pressure = Force / Area).
  • Knowledge of unit conversions, particularly psi to inches of mercury (Hg).
  • Basic geometry to calculate the area of a circle.
  • Research the effects of atmospheric pressure on vacuum systems.
  • Learn more about vacuum cup design and its applications in various industries.
  • Explore advanced pressure measurement techniques and tools.
  • Study the principles of force and pressure in fluid mechanics.
Engineers, physicists, and students involved in mechanics or vacuum technology will benefit from this discussion, particularly those working with vacuum systems and pressure calculations.
Chris@ETI
I have a circular vacuum cup. The cup has a diameter of 4.5 inches. I need to calculate the amount of pressure, in inches of mercury (Hg), that the vacuum created by the cup would have to be in order to generate 120 pounds of force on a flat object.
None given.
It's been years since I've had to do any math or physics, but this is what I think is correct.
First, P = F/A, where P = pressure, F = force, and A=area
P = 120 pounds / ((2.25)^2 * pi) = 7.55 psi
Second, convert psi to Hg:
1 psi = 2.036 Hg, so 7.55*2.036 = 15.36 Hg
So, what I'm hoping for here is verification that I did this correctly or someone to set me straight on this.
Sounds right, you have to subtract the answer from atmospheric pressure ( about 15psi) to get the absolute pressure inside the cup.
You have calculated the pressure difference.
Thank you for you assistance on this.
I also apologize for my delayed reply, I was on vacation.
10K
