Sloped Bed Truck: Acceleration & Normal Force?
  • Thread starter Thread starter QuantumKing
    Truck
When a truck with a sloped bed accelerates horizontally, the normal force on a block resting on the slope decreases due to the truck's acceleration. The initial normal force is calculated as mg*cos x, where x is the slope angle. As the truck accelerates, the normal force is reduced by the term ma*sin x, which can lead to a scenario where the normal force becomes zero if the truck's acceleration is sufficiently high. This indicates that the block may lose contact with the slope if the acceleration exceeds a certain threshold. Understanding these dynamics involves considering an effective gravity in the accelerating frame of reference.
QuantumKing
If I have a truck with a sloped bed in the back, the truck is accelerating horizontally and there's a block sitting on the slope tied to a rope while all this is happening. I was wondering if the trucks acceleration would cause the normal force being applied to the block by the sloped bed to diminish?
Thanks
Certainly. If x is the angle between the slope and the horizontal, then initially the normal reaction was mg*cos x. If ‘a’ is the accn of the truck, then the diminished normal reaction is mg*cos x –ma*sin x. Note that the normal reaction could become zero if ‘a’ is high enough. Negative value means that the block is no more resting on the slope because the truck is accelerating so fast.
One way of calculating forces on static objects in accelerating frames is to think that there is an effective gravity of '–a' in that frame, on top of any actual gravity.
Thread 'Gauss' law seems to imply instantaneous electric field propagation'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (First part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8 and stuck at some statements. It's little bit confused. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. Solution : The surface bound charge on the ##xy## plane is of opposite sign to ##q##, so the force will be...
