Momentum, Completely Inelastic Collision
The discussion revolves around a physics problem involving a completely inelastic collision between two cars after a traffic accident. The key points include the use of momentum conservation to determine the initial speeds of both vehicles, despite kinetic energy not being conserved. The participant outlines the necessary equations, including those for friction and motion, to calculate the forces and accelerations involved. There is some confusion about the relationship between the variables representing the drivers' speeds and the derived components of velocity. The conversation emphasizes the importance of correctly applying physics principles to solve for the initial velocities of both cars involved in the collision.
lfwake2wake
Your friend has just been in a traffic accident and is trying to negotiate with the insurance company of the other driver to pay for fixing his car. he believes that the other car was speeding and therefore the accident was the other driver's fault. He knows that you have a knowledge of physics...(He must not know me very well :)...) and hopes that you can prove his conjecture. He takes you out to the scene of the crash and describes what happened. He was traveling North when he entered the fateful intersection. There was no stop sign, so he looked in both directions and did not see another car approaching. It was a bright, sunny, clear day. When he reached the center of the intersection, his car was struck by the other car which was traveling East. The two cars remained joined together after the collision and skidded to a stop. The speed limit on both roads entering the intersection is 50 mph. From the skid marks still visible on the street, you determine that after the collision the cars skidded 56 feet at an angle of 30 degrees N of E before stopping. (blah blah blah more facts): His car(1) is 2600 lbs and the other drivers car(2) is 2200 lbs (including weight of the drivers). Coefficient of Kinetic Friction= 0.80...I have to find both speeds of the drivers.
m1=Mass of Car 1 = 2600 lbs
m2=Mass Car 2 = 2200 lbs
uk=Coeff. Kinetic Friction = 0.80
dx=56 ft
@=Theta=30 degrees
mv=p where p is conserved.
All of Newton's laws of motion... vf=vi +at, dx=vit+1/2at^2, vf^2=vi^2+2ad
KE=1/2mv^2 (even though its a completely inelastic collision, i might use it)
friction=uN
F=ma
F(friction)*d=Work done by friction
Since it is a completely inelastic collision, KE is not conserved; however, momentum is conserved.
Here is the momentum equation:
m1v1(j)+m2v2(i)=(m1+m2)*V
Using dot product rules:
Vx=(m2v2)/(m1+m2)
Vy=(m1v1)/(m1+m2)
V=(Vx^2+Vy^2)^.5
Since F(friction)=uN, F=0.8*(2200+2600)*(g) =====>don't worry about converting, i'll do that.
So here can I solve for (a) using F=ma? I would have:
a=F(friction)/(2200+2600). Then using that, I could solve for t in above question. Is this correct or am I missing something important?
Once I solve for (t) I can solve for V(initial). Then I can substitute for Vx, Vy. When Vx=Driver 1, and Vy=driver 2.
most of it looks right. But why do you want to get t? Just get Vinitial directly. Then get Vx and Vy. then you can solve for v1 and v2.
but what do you mean by this:
? This isn't right. v1 is not Vx. v2 is not Vy.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
