Solving Fun Ski Area Problem: 3.67x10^7 W
  • Thread starter Thread starter Vanessa23
    Area Fun
The discussion revolves around calculating the required motor power for a T-bar tow in a ski area, specifically for pulling 82 skiers up a 609-meter slope at a speed of 2.37 m/s. The key equations involve forces due to gravity and friction, leading to the formula for power. The user initially calculated the power as 3.67x10^7 W but received feedback indicating the answer was incorrect. Confusion arises regarding the use of the normal force, with differing opinions on whether to use the mass of one skier or all skiers for calculations. Ultimately, clarification is needed on the correct application of the normal force in the context of the problem.
Vanessa23
[SOLVED] Fun ski area problem
A T-bar tow is planned in a new ski area. At anyone time, it will be required, to pull a maximum of 82 skiers up a 609-m slope inclined at 14.1° above the horizontal at a speed of 2.37 m/s. The coefficient of kinetic friction between the skiers skis and the snow is typically 0.0600. As the manager of the facility, what motor power should you request of the construction contractor if the mass of the average skier is 66.0 kg. Assume you want to be ready for any emergency and will order a motor whose power rating is 54.0 percent larger than the bare minimum.
N = mg cosθ
and
F = mg (sinθ + μcosθ)
and
Po = Fv
so solve for P in: P = (Po + .54 Po)N
P=((66.0*82*g)*(sinΘ + .06cosΘ))*2.37) +
(.54)*((66.0*82*g)*(sinΘ + .06cosΘ))*2.37)
I then multiply the answer for P times (66.0*g*cosΘ)
Answer=3.67x10^7 W
The program we submit our answers to says that my answer is wrong. I don't know what I am doing wrong. Thank you for any help!
This seems reasonable.
Why?? P is your answer.
Our professor went over the problem in class and said we should multiply it by N and N is mg*cos(theta). He said that when we figure out N we should use the mass of only one skier.
Sorry, but that makes no sense to me at all. It won't even have the correct units.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
