Making a piecewise defined function differentiable
brh2113
I have to find the values of a and b in terms of c so that this function is differentiable. Attached is the problem and my work, but I think that there's an error somewhere in my attempt. Any advice?
Yes, check your derivative of 1/|x| at x=c. It's not zero. You made an algebraic mistake.
I see I forgot to distribute a negative sign on the left side's derivative, but that's trivial, because as h-->0, (-h) and (h) both approach 0.
Is there something else I'm missing? I've re-done the rest of the algebra, and I'm still getting 0.
EDIT: I see what went wrong. I moved the h up to the top of the fraction, instead of keeping it on the bottom.
I think I've solved it (see attached). My only concern is that I've ignored the absolute value signs. Is this a problem? Or should I go back and work it through with two cases, one when X>0 or equal to 0 and one when X<0?
That seems to me the better way, but I'm wondering if it's necessary?
You posted an attachment, so I can't see it yet, but yes, you should probably do two cases. That's kind of what absolute values are all about.
Since f(x)= 1/|x| only for |x|> C for some positive number C, the derivative of 1/|x| at x=0 doesn't matter (fortunately)! What is crucial is the value and derivative of 1/|x| at x= C and x= -C.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
