Approximating Nearby Points on a Nonlinear Curve
anthonym44
To the right is the graph of 5x^3y-3xy^2+y^3=6. Verify that (1,2) is a point on the curve. There's a nearby point on the curve whose point is (1.07,u). What is the approx. value for u? There's a nearby point on the curve whose coordinates are (.98,v). What is the approx. value for v? Theres a nearby point on the curve whose point is (w,2.04). What is an approximate value for w?
f'(a)(x-a)+f(a)
the derivative of the equation is (15x^2-3y^2)/(-5x^3+3x^2y-3y^2)
I know how to do the first part, you plug in the values for x and y and they should = 6, which they do. However, for the remainder of the problem i am completely lost. I'm totally
lost, so if you can offer any input i would appreciate it. Thanks
f'(a)(x-a)+f(a)
The tangent line to a curve, y= f(x), through point (x_0, f(x_0)) on the line is y= f'(x_0)(x- x_0)+ f(x_0) and will give (approximately) the y value for an x value close to x_0. You are told that x_0= 1 and that f(x_0)= 2. What is f'(x_0)? That gives you all the information you need to construct the equation of the tangent line. Then use it with the two new points given to find the missing values.
Thanks. That helped me, I'm pretty sure I have it now.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
