Integrating over all possible fields
  • Thread starter Thread starter quantumfireball
    Fields Integrating
quantumfireball
What does it really mean to integrate over all possible fields in the Path integral formulation of quantum field theory,and how does such a formalism goes out to decribe
field quanta?
Another question is
im new to Quantum field theory
i was wondering whether i should stick to the old second quantization approach of QFT or would it be better to directly jump to path integral method of doing QFT
I suggest you to read the book "field theory" Ashko Das. ther is areal good deduction of path integrals... starting from Q.M. and then discretizing the Minkoskwy space time. before there is an introduction to path untegral approach an then you will get the idea of pertirbation theory and Feynman diagrams. If you want a canonical approach i suggest u QFT Itzykinson Zuber. this Book use the operator algebra not the Feynman Integral..
Buty show also the connection...
Quantum and statistical field theorie from LE BELLAC is a really good one also...
It is not so easy to transmit the power of Feynman view in a post.
but trust me... he invinted a new area and a new conception of QM. There was another INTERPRETATION (a new explanation). In DAS bookk u can find an euristic equivalence of feynman QM and Heisenberg/Schrodinger one...
bye
have a good time
Practicing Quantum Field Theorists almost always use path-integral quantization when deriving things. The modern concept of Effective Field Theory and RG analysis, as well as Yang-Mills quantization, are much more natural in this formalism. You should be sure to understand 2nd Quantization, but then you should try to get comfortable with Feynman - his formalism is what you'll most likely be using when doing research.
Not "Ashko Das" but "Ashok Das"
field quanta?
Another question is
A good pedagogic intro to QFT that starts from the path integral approach and explains it in a nice way is
A. Zee, Quantum field theory in a Nutshell (2003)
Not an expert in QM. AFAIK, Schrödinger's equation is quite different from the classical wave equation. The former is an equation for the dynamics of the state of a (quantum?) system, the latter is an equation for the dynamics of a (classical) degree of freedom. As a matter of fact, Schrödinger's equation is first order in time derivatives, while the classical wave equation is second order. But, AFAIK, Schrödinger's equation is a wave equation; only its interpretation makes it non-classical...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
Is it possible, and fruitful, to use certain conceptual and technical tools from effective field theory (coarse-graining/integrating-out, power-counting, matching, RG) to think about the relationship between the fundamental (quantum) and the emergent (classical), both to account for the quasi-autonomy of the classical level and to quantify residual quantum corrections? By “emergent,” I mean the following: after integrating out fast/irrelevant quantum degrees of freedom (high-energy modes...
