What Is the Speed of the Combined Blocks After Collision?
  • Thread starter Thread starter zvee_y
    Collision
zvee_y
A track consist of a frictionless arc XY, which is a quarter-circle of radius R, and a rough horizontal section YZ. Block A of mass M is releasecd from rest at point X, slides down the curved section of the track, and collides instantaneously and ineslastically with identical block B at point Y. The two blocks move together to the right. Express the answers in term of M, R, and g.
It asked to determind the speed of the combined blocks immediately after the collision.
Help me out please. This is the question from the AP test Physic B. I've tried to use the conservation of momentum after collision. But the initial velocity is 0, so how can i find the velocity after collision?Thank you
Good. Momentum is conserved during the collision.
The initial speed is 0 at the top of the arc, but the collision takes place at the bottom of the arc. Since the arc is frictionless, find the speed of block A when it reaches the bottom, just before it collides with block B.
so v=square-root-of 2gR
and the final velocity of 2 objects is vf=(square-root-of 2gR)/2
Is it right?
Right. That's the final speed of both blocks immediately after the collision.
Thank you!
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
