Polynomial Divided by (x-1)(x-2): Remainder & Why
  • Thread starter Thread starter Xalos
    Polynomial
When dividing a polynomial P(x) by (x-1) and (x-2), the remainders are 2 and 3, respectively. This implies that P(x) must be quadratic, as the degree of the remainder must be lower than that of the divisor. By setting up equations based on the remainders, it can be determined that the polynomial can be expressed in terms of coefficients a, b, and c. The critical division reveals that despite initial assumptions about the polynomial's form, the consistent remainders indicate a specific relationship among the coefficients. Ultimately, the discussion highlights the importance of recognizing polynomial degree constraints in remainder problems.
Xalos
Suppose a polynomial is divided by (x-1) and remainder=2 and when the same polynomial is divided by (x-2), remainder is 3. What is the remainder when the polynomial is divided by (x-1)(x-2)? Why?
Mathematics news on Phys.org
This may seem vague, but a remainder may either be a constant, or the degree in the numerator is lower than the degree in the denominator.
You can start with:
P(x) = D(x)Q(x) + R(x),
where P(x) is your polynomial and your dividend, D(x) is your divisor which might be a binomial or trinomial, Q(x) is the quotient, and R(x) is the remainder.
I worked your problem and it should not be too complicated. You should understand something about using synthetic division to obtain points of the polynomial. If you divide using synthetic division and you obtain a nonzero remainder, then the divisor number and the remainder will give you a point on the polynomial. If the root used is a and the remainder is b, then a point on the polynomial is (a, b).
You know three things:
Since the polynomial, P(x), divided by x-1, has a numeric remainder, it must be quadratic, of the form ax2+ bx+ c.
Since the remainder, when divided by x-1, is 2, P(1)= a+ b+ c= 2.
Since the remainder, when divided by x-2, is 3, P(2)= 4a+ 2b+ c= 3.
Subtracting the first equation from the second gives 3a+ b= 1 so b= 1- 3a. Putting that into the first equation, a+ 1- 3a+ c= 2 or -2a+ c= 1 so c= 1+ 2a.
Now, divide ax2+ (1-3a)x+ 1+ 2a by (x-1)(x-2)= x2+ 3x+ 2.
Thanx! It didn't occur to me that p(x) couldn't be anything other than quadratic.
Actually, I wrote out a long response arguing that this was a bad problem because there were too many possibilities and the couldn't all give the same remainder.
Until I did the critical division at the end and found out they did!
You could show us what you were writing anyway. The reason I might like to read it is that I did not make any assumptions about the initial unknown polynomial, and then I found a non-polynomial result (a binomial, in fact). I would try to be clear about what assumption I did make that I should not have made; or what assumption I should have made that I did not. My result was that P(x)= ( x+1). Not a bad result but it is not a polynomial. The division process lead only to a remainder, and no other coefficients. Should I have understood that I must expect at least a quadratic degree polynomial?
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
