Finding the Envelope of a Family of Curves with a Parameter
  • Thread starter Thread starter gtfitzpatrick
    Curves
gtfitzpatrick
Find envelope of the family of curves x^2cosΘ + y^2sinΘ = a^2 where Θ is the parameter
I tried differentiating and putting it = to 0 but this is coming up very messy, is there something I'm not seeing here?thanks
Thanks for getting back to me but I'm not sure i follow. Do i solve 1 for x say then sub it back in and solve 2?
That would be one way. Or you can try solving either equation for theta then substitute it into the other equation.
I differentiated eq1 with respect to theta and got
-x^2sin theta + y^2cos theta
which is eq 2 but i just can't figure out how to isolate The theta in such a way that i can sub it back into eq 1?
Try doing a system of equations:
<br /> \begin{align}<br /> x^2 \cos\theta + y^2 \sin\theta &amp;= a^2\\<br /> y^2 \cos\theta - x^2 \sin\theta &amp;= 0<br /> \end{align}<br />
You can solve it using linear combinations with your "variables" being \cos\theta and \sin\theta.
Thanks, for getting back to me but I'm not sure i know what you mean by linear combinations?
Did you ever learn how to solve systems of linear combinations? For example, let's say we have the system
<br /> \begin{align}<br /> x + 2y &amp;= 6\\<br /> 3x + 7y &amp;= 0<br /> \end{align}<br />
We can solve this by multiplying (1) by -3 then adding the two equations together resulting in:
<br /> -6y + 7y = 6 + 0<br />
which you can then solve for y. Once you have y, you can plug it into one of the original equations and solve for x.
For your problem, you can use an analogous method by solving, instead of for x and y as above, for \sin\theta and \cos\theta.
i've solved the 2 eqs simultaneously by multiplying eq 1 by x^2 and eq 1 by y^2
which gives me
cos theta=a^2x^2/x^4=y^4
and throwing that back in for
sin theta = a^2y^2/y^4+x^4
Im not sure is this the answer? or where do i go from there?
thanks
since theta is the parameter i think i should be trying to eliminate it from the equations
tan theta = y^2/x^2
theta = tan ^-1 y^2/x^2
which i sub back into give
x^2cos (tan^-1 y^2/x^2) + y^2sin (tan^-1 y^2/x^2) = a^2
i'm going mad trying to work this out!
What identity can you use to tie sin theta and cos theta together?
Suppose I thought there is the identity "sqrt[sin theta] * sqrt[cos theta] = 2 for any theta."
Then I can write sqrt[a^2x^2/(x^4+y^4)] * sqrt[a^2y^2/(x^4+y^4)] - 2 = 0, which would be the envelope.
thanks for being so patiant with me but i don't understand where
"sqrt[sin theta] * sqrt[cos theta] = 2 comes from
There is no such identity. Enuma Elish said "suppose I thought that" because he was trying to not to do the problem for you! Do you know of any real identity you could use instead?
cos^2theta +sin^theta = 1?
thanks for that got it now, i hope
