Potential Energy and maximum velocity
The discussion revolves around a physics homework problem involving a mass sliding down an incline, where the maximum velocity before reaching the bottom is 1.00 m/s. The kinetic energy at that point is calculated to be 0.2 Joules. The main focus is on determining the percentage of potential energy lost due to friction, which is converted into heat. Participants suggest using the height to find potential energy and then calculating the percentage of energy lost using the formula KE/H * 100%. The conversation emphasizes understanding energy conversion and loss due to friction in the system.
JSapit
The mass 0.40 kg is released and slides down the incline. The maximum velocity ( taken the instant before the mass reaches the bottom of the incline ) is 1.00 m/s. What is the kinetic energy at that time? What percentage of the potential energy of the system is not converted into kinetic energy due to friction? (converted into heat instead)
My question is with part b, and the percentage of potential energy lost due to friction.
U=mgh
k=(1/2)mv^2
The answer to question a, which is the amount of Kinetic Energy was 0.2 Joules.
However, I had no idea how to start part b.
Any help is appreciated, thanks!
Bumperooski. I tried dividing the amount of PE by KE, and vice versa, but that didn't work. Still lost :/
Is that all the info given?
Do they give any more info about the incline?
the hypotenuse of the triangle is 40 cm with the vertical portion at 7 cm.
I assume funky is working the same problem then?
Well, if you know the height, you can find the potential energy. And you know the final velocity, so you know the kinetic energy.
Now if all your potential energy didn't get converted to kinetic where did it go?
If you are having problems with just the percent part, the equation is KE/H * 100%
