What Is the Importance of Understanding the 4th Dimension?
_Mayday_
Hello, I am in the process of reading Black Holes, Wormholes & Time Machines and am somewhat confused, even though it is aimed at people like myself who have very little knowledge on the subject. I am reading about the 4th dimension now but I do not understand the relevance of researching into the 4th dimension or giving it a lot of thought. Jim Al-Khalilie, the author, has explained the fourth dimension as like being in a hollow sphere, and the fourth dimension would allow you to exit the sphere without getting any closer to any of the edges. What does knowing there is a fourth or second dimension universe mean? Is it just out of human curiosity or does it explain or help explain some theories. I'm really stuck here I am very interested in this subject, so do not think that I am saying it is useless because I have no idea really :-p
_Mayday_
If this is in the wrong part of the site please let me know so I don't do it again... :smile:
A great example is the film "Time Machine" .. the time traveler is trapped inside a rock so he can not move but going forward on time (moving on the fourth dimension) he moves to a place where the rock has disappeared.
Real physics in 4-D implies no motion , perhaps 4 dimension exists or is just a physical artifact to describe nature, if we could 'see' in 4 dimension i believe that the mistery of QM and Relativity could be solved.
Note that a position-vs-time graph is a 4-dimensional "[mathematical] space".
In introductory physics, one often simplifies the discussion and considers only one-dimensional spatial motion (say, along a line)... which yields a position-vs-time graph that is 2-dimensional.
Are you clear on what "dimension" means? A dimension is just a number specifying a specific thing. To designate a specific point in space requires 3 numbers no matter what coordinate system you use- it is "three dimensional". Physicists study "events": things that happen at a specific place at a specific time. We require three numbers to specify the position in space and a fourth to designate the time. That is what Einstein meant when he said "Our universe is a four-dimensional space-time continuum.
It appears that the text you are referring to is talking about a possible 4th "space" dimension- that would be somewhat speculative. There are a number of theories that involve higher space dimensions but none of them have been shown to be experimentally "correct" (there isn't any question about a "second dimension"!).
The analogy with the hollow sphere is this- Suppose there existed a being that lived only in two dimesions- that could move about on a sheet of paper, that could move "up or down" or "left or right" but knew nothing about "vertical" direction. A circle containing that being would be a prison it could not get out of. But if the creature could move vertically, it would could move outside the circle. Similarly, if there were a fourth space dimension, a three dimensional person could move out of a hollow sphere.
That wouldn't actually work if the rock is just moved rather than broken up into pieces. And that movie sucked. :smile:
Thank you, that has certainly cleared things up.
OK, so this has bugged me for a while about the equivalence principle and the black hole information paradox. If black holes "evaporate" via Hawking radiation, then they cannot exist forever. So, from my external perspective, watching the person fall in, they slow down, freeze, and redshift to "nothing," but never cross the event horizon. Does the equivalence principle say my perspective is valid? If it does, is it possible that that person really never crossed the event horizon? The...
In this video I can see a person walking around lines of curvature on a sphere with an arrow strapped to his waist. His task is to keep the arrow pointed in the same direction How does he do this ? Does he use a reference point like the stars? (that only move very slowly) If that is how he keeps the arrow pointing in the same direction, is that equivalent to saying that he orients the arrow wrt the 3d space that the sphere is embedded in? So ,although one refers to intrinsic curvature...
ASSUMPTIONS 1. Two identical clocks A and B in the same inertial frame are stationary relative to each other a fixed distance L apart. Time passes at the same rate for both. 2. Both clocks are able to send/receive light signals and to write/read the send/receive times into signals. 3. The speed of light is anisotropic. METHOD 1. At time t[A1] and time t[B1], clock A sends a light signal to clock B. The clock B time is unknown to A. 2. Clock B receives the signal from A at time t[B2] and...
