How Do You Calculate the Final Angular Speed of a Bicycle Wheel?
To calculate the final angular speed of a bicycle wheel with a diameter of 66 cm and an initial speed of 230 rpm, the torque generated by friction must be considered. The friction force, derived from a normal force of 2.7 N and a coefficient of friction of 0.46, leads to an angular acceleration of approximately -19.08 rad/s². Using the equation ω = ω0 + α * t, the final angular speed is calculated to be 17.962 rad/s, indicating a decrease in speed due to the applied torque. It's crucial to account for the negative sign in angular acceleration, as it reflects the deceleration of the wheel. This approach clarifies the calculation and confirms the final angular speed.
nightshade123
[SOLVED] Angular Speed
\tau = r * F
youve got our bicycle upside-down for repairs with its 66 cm diameter wheel spinning freely at 230 rpm. the mass of the wheel is 1.9 kg and is concentrated mostly at the rim. you hold a
wrench against the tire for 3.1s with a normal force of 2.7 N. if the coefficient of friction between the wrench and the tire is 0.46 what is the FINAL ANGULAR SPEED OF THE WHEEL?
diameter = 66 cm
radius = .033m
mass = 1.9 kg
Norm Force = 2.7 N
friction coef = .46
\omega0 = 230 rpm
\omega0 = 24.1 rad/s
w = ?
eqns
I = Mr^2
\omega = \omega0 + \alpha * t
\tau = r * F * sin(theta)
\tau = I \alphav=\omega * r
v=\omega * r
x
\tau = r * F
where F is the Friction Force
r*F = M * r^2 * \alpha
we can solve for \alpha and it = 19.08
\omega = ( \omega0 + \alpha * t )\omega = 85.48 rad/s
that means it sped up...
idk how to do this problem keep getting confused with the answers I am getting
any help?
thanks in advance for your time and effort.
initial angular speed= 230 rpm.
torque = r * f * sin 90 degrees
>> torque= .33 * .46 * 2.7 ( radius * frictional force)
calculate torque.
Now the big ques is:
What is the moment of inertia of a wheel?
nightshade123 said:
diameter = 66 cm
radius = .033m
You have a typo here that messed you up later. Radius = 0.33m.
x
\tau = r * F
Perfectly correct, except that you used the wrong value for the radius.
Note that the angular acceleration created by the friction is opposite to the initial angular velocity, so the wheel slows down.
im having trouble interpreting my answer
asuming that is right
then i put it in this eqn to find \omega = 30.238 rad/s
so next i would take \omega - \omega0 to find the change over 3.1 sec?
thus producing an answer of 6.138 rad/s
and then they want to know final angular speed so 24.1 - 6.138 = 17.962 rad/ s^^^^that was the more logical approach ^^^^vvvv you can also say that vvvv
this one just produces the same answer negative, so that's why it doesn't make sense
\omega = 24.1 rad/s
solve for \omega0 and you get -17.962 rad/s, but then you got to change the sign, which u can because it asks for speed
That's the initial angular speed.
As I already pointed out, the acceleration is negative. Done correctly, this will give you the final speed.
The change is just alpha*time. What is your value for alpha?
Seems like you're doing a bit of extra work.
\omega = 24.1 rad/s
Not sure what you're doing here. Why would you solve for the initial speed? That's given.
\omega will not increase. It will decrease. You have to put a negative sign before \alpha in that equation.
that makes sense! and it produces the 17.962 rad/s instantly! thanks for the help
doc al, since i forgot to change accel to negative i showed how to produce the same answer, but with a lot more work, lol and i was just throwing out that idea for the 2nd part, i knew it didnt make sense but it was worth mentioning.
