Back EMF (electromagnetic induction)
The discussion explains that when a motor's coil is energized, it spins and cuts through a magnetic field, inducing a back EMF that opposes the current. This back EMF requires additional electrical energy to maintain the motor's rotational speed, as described by Lenz's Law. The energy needed to overcome this back EMF comes from the power supply, such as a battery. The initial electrical current does contribute to the motor's kinetic energy, but ongoing energy is required to counteract the induced back EMF. Understanding this relationship is crucial for grasping how motors operate efficiently.
v_pino
1)When the current through the coil of a motor flows it cases the coil to spin.
2)The spinning motion causes the wires in the coil to cut through the magnetic field.
3)The current induced (back EMF) in the wires by this spinning motion opposes the change that causes it. (Lenz's Law)
4)Current supplied against this EMF requires electrical energy.
5)It is this energy that is converted to the kinetic energy of the motor.
I don't understand 4) and 5). Where does this electrical energy come from? I thought the motor's kinetic energy comes the the initial electrical current supplied to it...
Thanks.
I am a bit confused too but I think that:
Whenever a current carrying coil is put in a magnetic field, a torque acts on it. This is responsible for its rotational motion and forms the working principle of galvanometers.
But this rotational motion causes the induction of opposing emf and this tends to resist the rotation. So to keep up the same rotation rate more energy needs to be supplied. So it is this energy which gives the motor its kinetic energy.
Thanks.
The energy comes from the Battery or the power supply supplying the motor. The back emf generated is very small compared to the source emf.
This is from Griffiths' Electrodynamics, 3rd edition, page 352. I am trying to calculate the divergence of the Maxwell stress tensor. The tensor is given as ##T_{ij} =\epsilon_0 (E_iE_j-\frac 1 2 \delta_{ij} E^2)+\frac 1 {\mu_0}(B_iB_j-\frac 1 2 \delta_{ij} B^2)##. To make things easier, I just want to focus on the part with the electrical field, i.e. I want to find the divergence of ##E_{ij}=E_iE_j-\frac 1 2 \delta_{ij}E^2##. In matrix form, this tensor should look like this...
Thread 'Applying the Gauss (1835) formula for force between 2 parallel DC currents'
Please can anyone either:- (1) point me to a derivation of the perpendicular force (Fy) between two very long parallel wires carrying steady currents utilising the formula of Gauss for the force F along the line r between 2 charges? Or alternatively (2) point out where I have gone wrong in my method? I am having problems with calculating the direction and magnitude of the force as expected from modern (Biot-Savart-Maxwell-Lorentz) formula. Here is my method and results so far:- This...
