E-Material and e-Solutions for Engineering e-Learning
  • Thread starter Thread starter engware
    Engineering
The discussion highlights a website offering free e-material and e-solutions for engineering e-learning, focusing on energy conversion systems, including power and propulsion. Key topics covered include physical properties, steam approximations, and basic thermodynamic cycles like Carnot and Brayton. The site features sections for coursework material, PDF resources, online calculators, and plots, all aimed at enhancing engineering education. The original website URL has changed to http://www.engineering-4e.com, necessitating updates to any previous links. This resource is deemed valuable for students and professionals in the engineering field.
engware
To All:
Here is an engineering site, http://engware.i-dentity.com, that contains free e-material and e-solutions for engineering e-learning.
This site deals with technical background information and technical performance analysis of energy conversion systems (power and propulsion) -- physical properties, steam approximations, simple and basic cycles (Carnot, Brayton, Otto and Diesel), cycle components/processes (compression, combustion and expansion) and compressible flow (nozzle, diffuser and thrust).
Here are a few site useful sections and their corresponding URLs:
Coursework Material
http://engware.i-dentity.com/courses.htm
PDF Coursework Material
http://engware.i-dentity.com/pdfs.htm
Online Calculators
http://engware.i-dentity.com/calcs.htm
Plots
http://engware.i-dentity.com/plots.htm
Thanks,
Gordan
Nice website, engware! Pretty useful resources.
To All:
My website URL has changed from http://engware.i-dentity.com to http://www.engineering-4e.com.
Please replace the URLs in my original post as indicated in order to get the URLs to work -- otherwise, the URLs are just of no use ...
Thanks,
Gordan
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
