Quantum myth 1. wave-particle duality
95 replies · 19K views
pellman
Demystifier has a paper available entitled "Quantum mechanics: myths and facts". http://xxx.lanl.gov/abs/quant-ph/0609163 This is a fine overview of a lot of stuff which I would like to understand better. Please join me in discussing.
There are 9 myth categories. By myth the author means widely repeated statements which, true or false, are not something we can validly assert given our current understanding.
myth category 1. Wave particle duality (see section 2 of the paper)
The gist of section 2.1 is that based on the usual interpretation of QM, there is only the wave. What we call particle is merely the special case of a localized wave packet--of finite width and only ideally a delta function in the limit of [tex]\Delta x \rightarrow 0[/tex].
I have two tentative objections.
(1) The single particle wave function [tex]\psi (x,t)[/tex] can be misleading. It suggests something like an EM wave or a fluid wave. That is, a field, a value at each point in physical space at a given time. But this is wrong of course. For two particles we don't have [tex]\psi_1(x,t)[/tex] and [tex]\psi_2(x,t)[/tex] (although that may be approximately true if they don't interact) but rather [tex]\psi (x_1, x_2; t)[/tex]. The wave function lives in configuration space not physical space. Hence, it is not physically real but instead only a calculational tool.
That is, unless we are willing to grant configuration space a sort of platonic reality that is more real than the physical world that we experience with our senses. A logical possibility of course. The world of normal space time of our experience may merely be the result of how our brains+senses fit in as part of the universal wave function. In that case one could say that the wave function is the reality and it is the world of our experience which is the "calculational tool" provided to us by evolution for survival.
But this is a position of which I think we should be very suspicious. The most glaring problem with it in my opinion is the "measurement problem" and the fact that we don't observe superposition of macro objects, a fact for which the wave function alone has no answer. And for other reasons which will come up as we discuss the "myths".
(2) Particle position plays such a central role in actual measurements. I have heard it said that all measurements ultimately reduce to positions measurements. (But is this one more myth?)
This suggests to me that the usual formulation of QM is only an approximation and that a better theory would be a particle theory. And indeed, in Sec 2.2 Demystifier discusses such a possibility in the Bohmian interpretation.
But what do we even mean by "particle"? I have to admit that at this level I have better mental grasp of the wave function than what a "particle" is or might be.
Could be. But I don't know any counterexample. Does anybody?
There is no duality, and things such as light is neither a "particle" or a "wave". Quantum mechanics provide a singular and consistent description.
calorimeter?
pellman said:
... I have heard it said that all measurements ultimately reduce to positions measurements. (But is this one more myth?)
Wow...where did you hear that? I personally have always thought this to be the case and I even said so in a recent thread in the GR forum (I even said that, as far as I can tell, even all time measurements actually reduce to position measurements...) and one of the forum monitors closed down the thread basically calling me a crackpot!
interesting thread by the way. I have always wanted to discuss that very interesting paper by Demystifier
Re [tex]\psi (x_1, x_2; t)[/tex]..A similar form for E and B will hold in classical E&M for example, for two charged particles interacting and radiating with the E&M field. And there's always a mapping from configuration space -- as you define it -- to physical space. Think, for example, also about Hamilton-Jacobi Theory and how it is formulated.
Regards,
Reilly Atkinson
I don't know. I am sure I have heard and read it a number of times. That is, ... er ..I was sure ...
Haelfix said:
calorimeter?
Let's see if I understand. A calorimeter is a thing in which an energetic particle is directed and its energy ultimately transferred to a dense material. From the change in temperature of the material we infer the energy of the original particle. Right?
Now that I think about it, the claim about all measurements reducing to position measurements is probably in the sense that the measurement is made by checking the position of something, not necessarily a quantum particle. In the calorimeter case, the change in length or volume of the material associated with its change in temperature? (I don't know how the temp change is measured.) Something like that.
But this position measurement would be a quantum variable. There would be an uncertainty in the observation. In this case it would likely have to do with energy/time uncertainty. When do we note the temperature change? When can we safely say all the energy has dissipated throughout the material?
Clearly, I haven't thought it through carefully. But that is the gist of it, I suppose.
The time/energy uncertainty relation is handled in a later section of the paper, btw.
I can understand “consistent description” limited to detail no finer than allowed by HUP.
But what might you mean by “singular description” ?
Seems to me there are a multitude of descriptions, all consistent within the limits of QM.
BM, MWI, oQM, Strings, etc.
This seems to fall more in the category of something we currently cannot validly assert, or a myth as defined in the OP.
RandallB, I made a poor choice of words.
I meant that there wasn't really a particle/wave duality. Perhaps I should have used single (in contrast with dualist) instead.
[...] This suggests to me that the usual formulation of QM is only an approximation
In QFT, the standard meaning of "particle" is "unitary irreducible representation (unirrep)
of the Poincare group", which I think is a good meaning - as far as it goes.
Multi-particle/composite states are then constructed as tensor products of these
basic unirreps. But this runs into trouble when interactions are introduced, and controversy
when we try to define localization operators. There's more problems when we try to do
QFT beyond the confines of special relativity and the Poincare group.
I really don't think wave/particle duality should be called a myth. Maybe "misnomer" is more appropriate. The apparent paradox between wave-like and particle-like behavior remains the most fundamental mystery of QM and is hardly a non-issue.
It doesn't look very mysterious to me.
What is wrong with the wave function as a physical reality?
Is the EM field not a physical reality? What about the success of all the modeling
theories which use the electron field in a similar way as the EM field, as a continuous
charge and spin distribution?
Just ask Google:
1,660,000 hits for: "Density Functional Theory"
_,_75,000 hits for: "Copenhagen Interpretation"
_,_45,000 hits for: "Bohmian"
The hits are there because it's a proven reality, an industrial success.
Nobody has ever detected a point-like particle...
A flash on a detector screen is easily 10^15 times larger as the minimum size
for which some aspects of Quantum Field Theory have proven to be still valid.
Regards, Hans
Guess you're just smarter than me.
If the wave function collapses due to a change of information available about the system (which the classical electromagnetic field does not do), then it seems that the wave function does not represent reality, but only our information about reality. Unless, of course, you are an extreme positivist who identifies information about reality with reality itself.
Or maybe you are just smarter than him. Feynman said something like "If you are not confused with quantum mechanics, than you do not understand it." :wink:
That is true. But it is also true that nobody ever detected a particle as a wave. For example, in famous double slit experiments that demonstrate the wave nature of particles, in every measurement of a single particle you actually observe this small flash.
Hans de Vries said:
Just ask Google:
422,000,000 hits for: "God"
14,200,000 hits for: "Santa Claus"
I guess it is because these are even better proven realities. :smile:
IMHO, the real practical as well as fundamental problem, is that anything we learn about anything, needs to be acquired. There seems to be an information process through which knowledge is acquired, and I think that the nature of this process is a non-trivial way acutally has profound impacts on reality itself. Becaseu this isn't the isolated problem of a human scientist, I think all elements of the universe, including particle systems are bound to face the analog problem. A particle can hardly predict it's environment completely. And this should have consequences when you look statistically on group dynamics and complex systems.
So no matter what you think nature really is, I focus on exactl how do you conclude that, and how confident are you in the conclusion itself?
I can not even imagine the meaning of trying to picture that nature "really is" in a way that bypasses the learning/acquisition process? Such classical realism IMO seems to release itself from observability ideals, that IMO releases itself from my idea of the scientific method.
I consider the information a given observer have about it's environment is as real as anything possibly gets. It's an "image of reality" but this image is all he has, wether he wants is or not. But of course this images is in constant motion. The dynamics of this image is what I think interactions is about. Clearly the actions of this observer will depend on this image as well, which is thus also dynamical.
But I agree that QM as it currently stands doesn't reflect this to the full extent. One problem IMO is that QM is still too deterministic. The concept of deterministic probabilities makes no sense to me in this sense. I think the deterministic evolution is emergent in special cases. It's the limiting case where our incomplete guesses, happens to be in agreement with the expectations of the environment, then our guesses will appear to be like deterministic predictions. But thinking they are fundamentally deterministic, and taking that to be a principle of the foundations, that can be used for reasoing and extending the theory is IMO a mistake.
I think one confusion conclusive criticts that realists have on this, is that it would limit our ability to learn and make progress. And that accepting QM weirdness is like throwing in the towel. IMO that is a totally twisted conclusion, because IMO the fact that I don't know, does NOT mean I can't learn in the future. My personal poitn is that it is not possible at the present to determine the dice of tomorrow with certainty! So what is rated with probability zero today, might happen tomorrow. That is part of the indeterminism of the probabilities. But this is not realized in current QM formalism, which is why I still think that we need a fundamental revision of QM.
But I still maintain strong observability ideals and information perspectives. There is no contradiction here. I think the key is the physical basis of probability, this needs more attention in physics. The physical basis of the axioms of probability in relation to something observalbe it IMO very vague in current models.
/Fredrik
It is true that the E&M field depends on the position of particles. So for two sources we could write the value of the field at the point x as [tex]F^{\mu\nu}(x,t;x_1,x_2)[/tex]. But the point is that this is the value of the field at the point x. There is nothing analogous to this for the quantum wave function. There is no "value of the wavefunction at the point x". In principle, there is a single wavefunction for the whole universe, [tex]\Psi(x_1,...,x_N; t)[/tex] where N is the number of particles in the universe. (I'm talking non-relativistic QM here of course.) And it's value is not dependent on actual positions of those particles. Rather, it has a value for every possible arrangement of the "particles".
Pretty tough to swallow as the reality, IMHO.
But this is just what I mean. Don't we agree that the Hamilton-Jacobi function is merely a calculational tool? It's value is only in its ability to lead us the equations of motion of the individual particles.
LOL. I didn't want to sound too arrogant, but yes that came to mind.
That's exactly right. As soon as you try to impart physical meaning into the wave function is when you start to get paradoxes. That's why I lean toward MWI, because its explanation of wave function collapse (i.e., the universe splitting to reflect the new information that is obtained) is the simplest and most intuitive _physical_ interpretation IMO.
On the other hand, it's possible that we simply don't understand enough about statistical and information theory to link the wave function to reality, and that if we ever develop better logical/informational models the paradoxes will disappear.
What proof is there that interactions only involve wave function collapses?
A photon which refracts through a lens and travels at 65% of the speed
of light has to interact with ~10^20 dielectric molecules which all need to
move "up and down" with each period of the photon to make this possible.
What proof is there that these interactions don't take place because there
is only one flash on the detection screen?
The same is true for the wave function of the electron field. How can the motion
of the nuclei due the electron field be modeled by Quantum Molecular Modeling
if the wave function is only a mathematical construct and the "real physics"
involves just little billiard balls?
Regards, Hans
That sounds like my horse :)
/Fredrik
Hurkyl said:
peter0302 said:
I really don't think wave/particle duality should be called a myth. Maybe "misnomer" … … wave-like and particle-like behavior remains the most fundamental mystery of QM and is hardly a non-issue.
That doesn’t seem logical and rational to me.
You don’t explain why this paradox is no mystery to you, so I can only assume it is because you accept QM CI as not just accurate but correct and complete.
That should mean you accept reality must not be both “local and realistic”, allowing for weird action at a distance. I.E. you accept that reality itself is in fact mysterious. Which also should mean you accept “wave-like vs. particle-like” as a part of a mysterious fact of nature.
Thus I can only conclude you think “wave-like vs. particle-like” is mysterious, but question the degree of mystery as not being large enough to call it “very” mysterious.
Otherwise you would be a total mystic that rejects rationalism to the point of not accepting the scientific method and I don’t read you as one of those.
RandallB -- I cannot follow any of the reasoning in your post. It certainly does not appear to be 'rational and logical' grounds for me to discard my self-assessment of being "not mystified".
And, quite honestly, I do not really understand why someone would be mystified at the fact a quantum state can, approximate the behavior of a classical particle in some circumstances, and approximate the behavior of a classical wave in some circumstances. I could speculate, but it would merely be speculation.
For the record, I also do not find "weird action at a distance" mysterious.
I agree with Hurkyl. It seems most people that that a problem with wave-particle duality, Bell's etc make the implicit assumption that nature should "make sense". However, as far as I can tell there is no reason to believe this to be the case.
The litmus test for a scientific theory is if it makes predictions that agrees with experiments, if it does we say that it is "correct" in the scientific sense.
Hence, it might turn out that our most accurate theories will one day tell us that e.g. nature is both non-local and non-realistic which would certainly be "weird", but if those theories agree with experimental data then we will have to accept them. And, as with most "weird ideas", once we get used to them they won't appear so "mysterios" anymore. Jjust think about SR, time dilation was definitely something "mysterios" idea back in 1905, but now we are used to the idea.
Whether or not our theories have anything to do with a "reality" in a philosophical sense(which tend to be what these threads end up discussing) might be an interesting issue to debate, but it is ultimately irrelevant from a scientific point of view.
Personally, I don't worry about it anymore but maybe that is because I am an experimentalist; as long as I am able to use the various aspects of QM to plan, analyze and understand the outcome my experiments I am happy:smile:
The title of this section in Demystifier's paper is In QM there is a wave-particle duality. That, I think we can all agree, is certainly a myth. In the theory there is only the wave-function or state-vector [tex]|\psi\rangle[/tex]. The theory has nothing to say about particles, only about "observables" and the probability of observing one to have a certain value--though leaving "observing" undefined.
If there is a particle-wave duality in our understanding of the data, it is outside of QM theory proper.
What about QFT and so-called particle theory? Are there particles in particle theory?
I agree with Demystifier & Feynman. But science has many opinions & views that can be held with certainty and passion.
