Weird Issue with the Chain Rule
Kreizhn
I'm working on a quick problem regarding a presentation that I'm giving, but I've come across an issue that I can't seem to resolve. Namely
\displaystyle \left. \frac{d}{dt} \right|_{t=0} f(\phi^p (t+t_0) ) = \left( \phi^p \right) ^\prime (t_0) f
Does anybody see how this is true?
\displaystyle \left. \frac{d}{dt} \right|_{t=0} f(\phi^p (t+t_0) ) = f^\prime(\phi^p(t_0)) \left(\phi^p \right)^\prime (t_0)
All we know about f is that it is a smooth function and t_0 was arbitrarily chosen, so I'm not seeing where we make the jump. (Note: \phi^p(t) is a dynamical system flow on a smooth manifold, but I don't see how that should help)
Is f some form of exponential, so f'(x)=f(x)?
All we know is that f is a smooth function on the manifold.
That first equation looks incomplete to me. There is no argument to f.
f is defined as a function on the manifold so the argument is generally omitted; otherwise, we would need to introduce an atlas on the manifold and define a local coordinate system using a coordinate chart. I don't think it's really necessary to the argument. Furthermore, (\phi^p)^\prime is a locally defined vector field, and \phi^p being a flow would imply that vector field is smooth. Thus it acts as an operator on f, in which case the argument for f is again not necessary.
I think the answer was staring me in the face the whole time.
I probably should have defined flows, it would've made this a bit more obvious.
The flow maps the Cartesian product of a monoid and a manifold to a manifold. But \frac{d}{dt} is a derivative that holds only with respect to the monoid. The way that that is written isn't implying that \phi^ is in the argument of f, it's implying that this is indeed the product of two smooth functions, one of which is completely independent of t!
I think that must be the answer, but I really blame horrible and ambiguous notation...
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
