Op-Amp: voltage-follower question
  • Thread starter Thread starter WalkingInMud
    Op-amp
In a voltage-follower configuration using an op-amp, the output voltage (Vout) ideally equals the input voltage (Vin), resulting in a closed-loop gain of 1. When a resistor ratio of 9:1 is mentioned, it typically refers to a non-inverting amplifier setup rather than a true voltage follower. In this case, the resistors are positioned in the feedback loop, with one resistor connected from the output to the inverting input and the other from the inverting input to ground. The closed-loop gain can be calculated using the formula Vout = Vin * (1 + R2/R1), where R2 is the feedback resistor and R1 is the resistor to ground. Understanding these configurations is crucial for accurate circuit design and analysis.
WalkingInMud
Op-Amp: "voltage-follower" question
Hi all, ...
If a simple op-amp circuit is described as:
-> being in a "voltage-follower with-gain" configuration, and
-> having a resistor ratio of 9:1
...Where are the two resistors positioned with respect to the op-amp circuit element, and
...How, if at all, doe they come into play when calculating the configuration's "closed-loop gain"?
Thanks heaps!
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
