Reaction for G-3-P oxidizing to 1,3-BPG
  • Thread starter Thread starter teddy1975
    Oxidizing Reaction
The reaction for the oxidation of G-3-P to 1,3-BPG involves G-3-P, NAD+, and inorganic phosphate, producing 1,3-BPG, NADH, and a proton. The hydride ion (H-) leaves G-3-P, transferring two electrons and one proton to NAD+, forming NADH. The additional proton in the products comes from the substrate's transformation, which results in a positively charged intermediate that cannot exist, leading to the release of a proton. This process can also be viewed as the substrate abstracting an OH- from water, resulting in the generation of a proton. Overall, the discussion emphasizes the stoichiometry of the reaction rather than the detailed mechanism.
teddy1975
okay, so here's another question: the reaction for G-3-P oxidizing to 1,3-BPG is:
G-3-P + NAD+ + Pi --> 1,3-BPG + NADH + H+.
I understand that the hydride ion leaves G-3-P and donates two electrons and one proton, which neutralizes the charge on NAD+ and gives NADH. But it is only giving one 'hydrogen', while the product side of the reaction shows another one (the hydrogen proton). Where does this hydronium ion come from? Why is it in the reaction? I read somewhere that it is pulled out of 'solution', but what does that mean?
I am no biologist but I think it is Cytochromes in the mitochondrial inner membrane.
Your question would be the same for any NAD+/NADH or NADP+/NADPH oxidoreductase. (Glcyeraldehyde-3-phosphate dehydrogenase is a bit more complicated than others because you also have a phosphorylation, but your problem is not about that.)
Just think first of a neutral substrate being oxidised to a neutral product, like alcohol -> aldehyde. H^- is transferred to NAD+ giving you the neutral ring NADH as you have explained. What would that leave the alcohol? A positively charged molecule with unpaired electron that can't exist. Write down the structure and you will find yourself predicting that and electron pair folds into make a double bond C=O leaving a free proton so you have accounted for your proton production. In our case, oxidation of an aldehyde, the impossible positively charged subtrate molecule after the H- has left takes on an OH-, so finishes up neutral acid molecule RCOOH. Absorbtion of an OH- is equivalent to production of a H+. Alternatively you can think of the substrate abstracting an OH- from an H2O molecule leaving an H+.
(Then just as a complication the acid molecule which is formally RCOOH, at physiological pH's will be practically totally dissociated into RCOO- + H+.)
Note here we are not too concerned with exactly how it happens, the real steps or 'mechanism', just with the overall results or starting and end products, the 'stoichiometry'. The reaction is equivalent to transfer of H2 to NAD+, or reduction of the NAD, by an H2 molecule; H2 is equivalent to H- + H+.
Sorry, just delete the "with unpaired electron" above.
Try and predict with 'bow and arrow' chemistry what happens when the H- leaves.
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
