Helium & Hydrogen Escape Rates: Table & Physical Mechanism
  • Thread starter Thread starter wasia
    Escape
Gas permeability charts for Helium and Hydrogen can be found through Google, Google Books, and local university libraries. Greenhouse's "Hermeticity of Electronic Packages" is recommended for detailed information on this topic. The physical mechanism of gas escape involves gas atoms entering solids, occupying interstitial sites, or moving along grain boundaries. Gas permeation occurs as numerous gas atoms diffuse through the material and exit. Understanding these mechanisms is crucial for applications involving gas containment and material selection.
wasia
Where could one find a table of Helium and/or Hydrogen escape rates through various materials? What is the Physical mechanism: is it tunneling only or other things contribute as well?
Thanks!
You are looking for gas permeability charts and tables, some of which can be found through Google and Google Books (and your local university library). Are you looking for any materials in particular?
I don't have the book handy, but Greenhouse's Hermeticity of Electronic Packages has a lot of useful information.
The mechanism is that a gas atom enters the solid (in crystals, it might occupy an interstitial site or travel down grain boundaries) and randomly moves around. Gas permeation involves many, many gas atoms that diffused through and exited the other side of the material.
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'What type of toilet do I have?'
I was enrolled in an online plumbing course at Stratford University. My plumbing textbook lists four types of residential toilets: 1# upflush toilets 2# pressure assisted toilets 3# gravity-fed, rim jet toilets and 4# gravity-fed, siphon-jet toilets. I know my toilet is not an upflush toilet because my toilet is not below the sewage line, and my toilet does not have a grinder and a pump next to it to propel waste upwards. I am about 99% sure that my toilet is not a pressure assisted...
After over 25 years of engineering, designing and analyzing bolted joints, I just learned this little fact. According to ASME B1.2, Gages and Gaging for Unified Inch Screw Threads: "The no-go gage should not pass over more than three complete turns when inserted into the internal thread of the product. " 3 turns seems like way to much. I have some really critical nuts that are of standard geometry (5/8"-11 UNC 3B) and have about 4.5 threads when you account for the chamfers on either...
