Laser cooling, varying magnetic field.
sc86
Okay, I have been reading the article Laser Deceleration of an Atomic Beam by William D. Phillips see attachment.
But I have a few problems:
1. Optical Pumping.
On page 1, 2. column they write:
The field both Zeeman tunes the decelerating atoms into constant resonance with the fixed frequency cooling laser and produces selection rules and Zeeman shifts that strongly discriminate against optical pumping.
I don't quite get the last part. How can the Zeeman effect change the selection rules?
2. Messurement of the velocity.
They decribe how they get the signals A (cooled atoms) and B (not cooled atoms), but how do the analysing laser work, when it messures the fluorescence?
And how is this fluorescence related to the velocity?
Hope some of you can give me a helping hand here.
/Stefan
This is a homework problem?
I'm not entirely sure about the "field produces selection rules" part, it has been over 10 years since I worked in this area. It might help to know what F is for the unused hyperfine ground state (the one for which there is concern about being optically pumped into). Do you know F for this state?
In Fig. 1, it appears that a lens is used to take the fluorescence (spontaneously emitted light, due to excitation by the analysing laser) and focus it onto a photodetector of some kind.
It is related to the Doppler shift.
##|\Psi|^2=\frac{1}{\sqrt{\pi b^2}}\exp(\frac{-(x-x_0)^2}{b^2}).## ##\braket{x}=\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dx\,x\exp(-\frac{(x-x_0)^2}{b^2}).## ##y=x-x_0 \quad x=y+x_0 \quad dy=dx.## The boundaries remain infinite, I believe. ##\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dy(y+x_0)\exp(\frac{-y^2}{b^2}).## ##\frac{2}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,y\exp(\frac{-y^2}{b^2})+\frac{2x_0}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,\exp(-\frac{y^2}{b^2}).## I then resolved the two...
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
