Find integral of 3x^2 e^2x^3 for x
  • Thread starter Thread starter staples82
    Integral
staples82
Use substitution to find: (3x^2)*(e^2x^3)*(dx)
I don't know how to do the integration sign...
u=2x^3
du=6x^2
this is where I got confused, my teacher isn't that good and I'm trying to understand how to substitute...
I know that its supposed to be e^u*du=e^u+c
the answer was (e^2x^3)/2+C
\int 3x^2 e^{2x^3}dx
u=2x^3 \rightarrow \frac{du}{dx}=6x^2 \rightarrow du=6x^2 dx
which is the same as \frac{du}{2}=3x^2 dx
You understand up to here right?
Now you can write the integral as this
\int e^{2x^3} (3x^2 dx)
Now do you see what you can put at 2x^3 and (3x^2 dx) as?
I'm wondering why you did du/2=3x^2dx, also how did you get the math text?
Well you see, when you did the substitution of u=3x^2, a 'u' will appear to be integrated and you can't integrate 'u' with respect to x. So what we need to get something to replace 'dx' with and \frac{du}{dx}=6x^2, if we multiply by the 'dx' we'll see that du=6x^2 dx. But in the integrand there is no '6x^2', only 3x^2. BUT 6x^2=2(3x^2), so that is why we divided by 2.
just use [*tex]What you want to represent mathematically[/tex*] without the *
Ok, so then that's why e^u/2 is the answer, I think I have to look at a few more problems, see if i can clear it up
Post back if you need more help.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
