Dividing a Circle into Equal Areas: A Mathematical Approach
  • Thread starter Thread starter futurebird
    Areas Circle Cut
To divide a circle of radius 1 into equal areas using parallel lines, the area under the curve f(x) = √(1-x²) is relevant. The integral of this function provides the area of the circle, which can be used to determine the cuts needed for equal division. The discussion also touches on the challenge of finding the specific locations for these cuts when dividing the circle into n pieces. A simpler method without calculus was initially sought but later deemed unnecessary. The conversation highlights the mathematical approach to achieving equal area divisions in a circle.
futurebird
Given a circle radius 1 how do you divide it into pieces of equal area using parallel lines?
Maybe find the area under f(x) = \sqrt{1-x^{2}}
OK
\int f(x)dx = \frac{1}{2} \left( x\sqrt{1-x^2} - \sin^{-1} (x) \right)
Well how do you find the location for the cuts if you need to divide the circle into n pieces?
This seems simple enough, but I can't figure it out.
Is there a better way to do this, without calculus?
Mathematics news on Phys.org
I've got it now. Never mind.
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
