Understanding the Speed of Power Transfer in Electrical Currents
The speed of power transfer in electrical currents involves both the speed of electrons and the propagation of electromagnetic (EM) fields. While the actual speed of electrons in a conductor is around 10^6 m/s, the electric and magnetic fields generated by these moving charges propagate at the speed of light. This means that although electrons move slowly, the effects of their motion, such as the current, are felt almost instantaneously due to the rapid propagation of the EM fields. For example, a 60 Hz oscillation creates a low-frequency EM field, while higher frequencies like those used in AM and FM radio operate in the hundreds of kHz to MHz range. Understanding this distinction clarifies the relationship between electron motion and the speed of current.
kiamzattu
Hi
I've a small doubt regardin the speed of power transfer.v know tat electric current produces electric and magnetic field around it. So is it an EM wave? if its so then it should travel at velocity of light right? on the other hand the speed of electrons in a conductor is around 10^6 m/s. since motion of electrons is current, what is d actual speed of current? is it d velocity of light or speed of electrons?
Regards
Anand
The 'current' is related to the speed of the electrons (and their charge) in the wire.
Each charge produces an electric field, and a moving charge (current) produces a magnetic field. Electric and magnetic fields propagate at the speed of light.
A 60 Hz oscillation would produce a varying EM field of 60 Hz, which is very, very low frequency. Consider AM radio is hundred of kHZ (or 0.5 - 1.7 MHz), FM radio is (~88-107) MHz, and microwave is on the order of GHz.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
