High Voltage DC Power Indicator
A 20kVDC pulse is being used for an igniter, and the goal is to energize an LED in sync with the pulses. It is not effective to wrap a coil around the power cable; instead, a current sense transformer should be used. This involves passing one lead of the power cable through a ferrite toroidal core and winding a secondary coil around it. The secondary coil's turns can be adjusted to generate sufficient voltage to power the LED. This method allows for minimal power extraction from the lead while ensuring the LED lights up.
rdvernon
I have a 20kVDC pulse flowing to an igniter. 2500 pulses per minute. I want to know if it is possible to use the high voltage pulses of DC to induce sufficient voltage in a coil wrapped around the power cable (through which the current is flowing) to energize an LED (in synch with the pulses). Any advice on this would be sincerely appreciated.
You don't wrap the coil around the power cable. To use the current in the cable, you need to form a "current sense transformer" where one lead of the cable goes through a ferrite toroidal core, and then you wind some number of turns on the toroid as a secondary coil. The one pass through the toroid by the power lead is a single turn coil, and your secondary has some number of turns that you tune to give you enough voltage to light your LED. This taps a little bit of power off of the power lead, but not much as long as you limit the current through your LED.
See "Instrument Transformers" or Current Transformers here: http://en.wikipedia.org/wiki/Transformer
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
